Page 10 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 91 to 100 of 175
Thread: RR 03-01-09 ... Couple more things..
  1. #91
    Nov 2004
    St Louis
    Great way to clog up the thead, Gizmo...
    Sorrrrryyyy! I tried a couple times to figure out how the built-in ACTVESOURCEID worked and every time it was explained, I got more confused. Then I decided I didn't like the order that MitchJS decided for us, so I created my own.
    Now, let's see if I can write some code to do what Sonic described. If I do I'll post it here, too, just for you.
  2. #92
    Nov 2007
    no help on the presets issue?
    should I got to a different thread? if so please redirect me. thanks.
  3. #93
    MySQL Error
    Oct 2004
    nav, i moved the xm stuff to a new thread
    http://www.mp3car.com/vbulletin/road...r-adaptor.html
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #94
    Oct 2006
    Bear, DE, USA
    I got my winamp install working, now iGuidance is complaining that I need to check that the GPS antenna is connected....but only when started from within RR....it works fine outside of RR, currently on COM6, which is reflected in rr.ini, and is being reported correctly by my skin (LSX V3). Stumped about that one.
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
  5. #95
  6. #96
    Oct 2006
    Bear, DE, USA
    Quote Originally Posted by Enforcer View Post
    Don't set the comport in RR.
    Roger that...thanks!
  7. #97
    Jun 2008
    Atlanta, GA
    Quote Originally Posted by mitchjs View Post
    sonicx,
    #1 its there... but... one thing of note "RADIORESET" only works if "radio on", and thats a loose term that has nothing to do with the radio actually being on
    isnt gonna be that simple... are u using HDRADIO?
    cause HDRADIO if rr is hibernate aware, closes the comport at hibernation, and at resumes opens it... no comport is left hanging
    if RR is hibernate aware. you might just have a simple hardware issue
    If I understand correctly, HDACTIVE indicates that the radio is tuned to a frequency with an HD signal on it, right? Would it be possible to have an indicator that shows the HD radio is connected (i.e. that RR is able to talk to it)?
  8. #98
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by spamminator View Post
    that'd be nice to have as well.
    Live mp3Car Facebook Chat
  9. #99
    MySQL Error
    Oct 2004
    COURSE, but i dont see the point, when you hd radio be connected and RR not able to talk to it?
    also when would hd radio not be preset and rr able to talk to it?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #100
    Jun 2008
    Atlanta, GA
    I suppose you are right -- though you could then base the RADIORESET command off of the indicator value...?
    Someone had mentioned above they were having problems with the HDRADIO coming out of resume. I have the same issue, but very rarely. The radio_player.skin loads but all I get over the speakers is static. All I have to do to get it to work is restart RR (which closes and re-opens the connection, I guess -- I can hear the radio click off and on).
    I guess I just wanted a way to easily tell if after a resume from hibernation the radio was A-OK. I know that when RR is starting up there is a pop-up if the radio isn't detected. Is this same check performed when resuming from standby?
  1. RR 03-10-05 - Few things..
    By guino in forum Road Runner
    Last Post: 03-11-2005, 02:16 PM
  2. RR 2-19-05 .. little things..
    Last Post: 02-20-2005, 01:55 AM
  3. Two things with RR 2-19-05
    By Passe in forum RR Bug Tracker
    Last Post: 02-19-2005, 03:02 PM
  4. Couple of things to get rid of
    By Adam F in forum Classified Archive
    Last Post: 02-16-2003, 02:11 PM
  5. Couple Things FS
    By Foobar in forum Classified Archive
    Last Post: 01-31-2002, 05:05 PM
