Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 161 to 170 of 175
Thread: RR 03-01-09 ... Couple more things..
  1. #161
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    I use ONSKINSTART to activate the VISU everytime I open the audio player.
    With the VISU I have many problem so I prefer to close it when I go out from audio player where. If I close RR with the VISU on, Winamp remain open, after when I reopen RR it couldn't start properly because it tries to open another section of Winamp.
  2. #162
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The "ONSKINSTART" is only called when the skin get loaded via startup or when switching skins.
    There already is a "ONSKINEND" Command.
    Seeing as he misunderstood what ONSKINSTART does, chances are ONSKINEND is not going to be the command he's after
  3. #163
    Mar 2009
    Italy
    It's simple:
    I use ONSKINSTART,VISU,audio_player.skin to activate the VISU when the audio player skin is opened and I close the VISU when I exit from audio player.
  4. #164
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by JohnnySierra View Post
    It's simple:
    why not just use AUDIO||VISU as your audio player command. No ONSKINSTART needed.
    Live mp3Car Facebook Chat
  5. #165
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    It's simple:
    And this just proves it.
    @Johny
    The "ONSKINSTART" is just like the windows startup folder, it only runs when you start up the computer, and onskinstart only runs when you first load a skin. The word skin refers to the whole collection of screens in a skin, each screen is a skin file but not called a skin but a screen and think that is what your misunderstood.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #166
    Mar 2009
    Italy
    Thanks for the clarifications, but I have another question.
    When I use "ONSKINSTART,command,xx.skin" the specified command is executed referring to the xx screen. But at the startup the xx screen isn't visualized, so when has the command effect?
    And about the screen when I load, for example, the browser screen from the audio player, remains this (audio player) loaded in the background or not?
  7. #167
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, the "ONSKINSTART" is mostly used by most to help setup the skin(set labels,set commands for dyno buttons). If what your trying to do is simply have it go to another screen after its done loading then you can either...
    #1 add "startcommand=Load;xxx.skin" to the rr.ini file
    #2 add "||Load;xxx.skin" to the end of the ONSKINSTART cmd in whichever skin your trying to modify
    I think you still have some terminology to learn with RideRunner
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #168
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Example:
    In ExecTBL.ini:
    "ONSKINSTART","AUDIO||VISU"
    When the skin is loaded (RR startup or skin change), RR will EXECUTE AUDIO||VISU commands.
    That's how ONSKINSTART works. It executes commands on skin start.
    That is the only time ONSKINSTART is used. On startup.
    I don't know if it's still loaded in the background because I've never tried it, but I'm guessing...yes.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  9. #169
    Mar 2009
    Italy
    Ok,
    so the correct use is "ONSKINSTART","command" without xx.skin.
    And what about my second question?
    When I load, for example, the browser screen from the audio player, remains this (audio player) loaded in the background or not?
  10. #170
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, RR will keep x screens in memory, where x is the screen limit set forth in the rr.ini and/or config. The setting is screenlimit=x. When you load a screen that isn't already loaded and in doing so would put the screens loaded count past the limit set, RR will first unload the oldest screen thats in memory and then load which ever one you were going to.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RR 03-10-05 - Few things..
    By guino in forum Road Runner
    Last Post: 03-11-2005, 02:16 PM
  2. RR 2-19-05 .. little things..
    Last Post: 02-20-2005, 01:55 AM
  3. Two things with RR 2-19-05
    By Passe in forum RR Bug Tracker
    Last Post: 02-19-2005, 03:02 PM
  4. Couple of things to get rid of
    By Adam F in forum Classified Archive
    Last Post: 02-16-2003, 02:11 PM
  5. Couple Things FS
    By Foobar in forum Classified Archive
    Last Post: 01-31-2002, 05:05 PM
