Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 175
Thread: RR 03-01-09 ... Couple more things..
  1. #11
    MySQL Error
    Oct 2004
    Jebus, thanks, YOU FOUND a bug in RRCONFIG
    Blue will FIX
    it does overwrite the PATH incorrectly, when done manually
    even if u just open RRCONFIG, and change something else, it WILL corrupt the setting
    THis needs to be fixed ASAP
    i dont have a prize to give ya
    just set it to AUTO
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Cool, Now where's my REP points!
    ...JJG
  3. #13
    Jun 2007
    Germany
    -Fixed "SETPATH" will now work with paths with no files in them
    does not function on my Skin.
    In my Picviewer Screen i try without a empty File and only Folders, it show nothing. So it is like before Update, i need a empty File to show the Folders.
    I use the old/normal Picviewer Screen, with only a simple DL $picspath$ and without any Imageviewer Program.
    On my Audio_Browser Screen i could not yet tested.
    -Or is this only for the Command "setpath"?
  4. #14
    MySQL Error
    Oct 2004
    not here toxic, i got a folder, and inside that folder, is just folders
    setpath;e:\_HW Projects\
    set it to that folder, and i see the other folders
    i just tried it on
    Jan09 build = DONT WORK
    March09 build = WORKS
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #15
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by Jebus View Post
    I was thinking that this was DaveDogs issue with his install...
    Winamp would not load with RR till I changed this, which made sense, Path was just "Winamp".
    ...JJG
    yep, that was it, but since RR doesn't support Win 7....
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  6. #16
    MySQL Error
    Oct 2004
    it just doesnt OFFICALLY support it (not yet) and i wanted to keep win7 stuff in its own thread, and the bug is in RRConifg for the winamp path, NOT RR
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DaveDog View Post
    As far as it's been tested, RR works on Win7 the same as in Vista (as mitch pointed out), The bug you're experiencing is the same bug anyone will experience if you don't set AUTO for the winamp path in the new config (as it's updated in the first post). I can't stress enough that if you're going to run RR in Vista or Win7 you MUST run everything as ADMINISTRATOR or it will NOT work right... I would HIGHLY suggest disabling UAC when using Vista or Win7, because while it is NOT required to be disabled, it is the most annoying thing I've even seen on any operating system, right next to the damn office paperclip.
    Ride Runner RR's Myspace
  8. #18
    Mar 2004
    Greenacres, WA
    my last post on this topic...
    I apologize profusely for stumbling onto an issue with the new release that happened to be an issue with RRconfig, regardless if it was running on Win7 or XP.
    I thought the idea behind the forum here was to share information, I shared and am getting grief for it.
    As far as the suggestions on how to run RR on Win7, I am WAY ahead of you guys.
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm sorry if I sounded apprehensive or something, cause I was only trying to clear up any confusion... not just for you, but anyone else that may have had the same problem... no grief, just trying to help.
  10. #20
    MySQL Error
    Oct 2004
    davedog, no one is giving you grief, i just re-read all the post...
    if its a WIN7 issue, post it in the win7 thread you got going, i read it
    since as soon as WIN7 goes RC, ill prob switch to it
    also, the language of your inital post was misleading, you said rr wont control winamp...
    if that path gets messed up, its like rr wont even launch winamp, thats how i caught it when jebus posted that
    since i run in auto mode for winamp location discovery, i never noticed, or i wouldn't have given a Green light on this release, i did test RRCONFIG, but i missed the bug I will try to be more diligent in future.
    now since ur on WIN7, would you like to be on the test team, for my next little project of making RR UAC compiliant?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 03-10-05 - Few things..
    By guino in forum Road Runner
    Last Post: 03-11-2005, 02:16 PM
  2. RR 2-19-05 .. little things..
    Last Post: 02-20-2005, 01:55 AM
  3. Two things with RR 2-19-05
    By Passe in forum RR Bug Tracker
    Last Post: 02-19-2005, 03:02 PM
  4. Couple of things to get rid of
    By Adam F in forum Classified Archive
    Last Post: 02-16-2003, 02:11 PM
  5. Couple Things FS
    By Foobar in forum Classified Archive
    Last Post: 01-31-2002, 05:05 PM
