Page 1 of 18 1234567891011 ... LastLast
Results 1 to 10 of 175
Thread: RR 03-01-09 ... Couple more things..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 03-01-09 ... Couple more things..
    In this Version:
    -Added ONPBDBLCLICK event
    -Added "EQ" setting to the preset cmd to only load the EQ settings; example: "PRESET;ROCK;EQ" (load/save "ROCK".pst file -- EQ data only)
    -Added Left/Right IL swaping setting (ILSwapLR=T/F, runtime setable )
    -Added "HDARTIST" label, returns artist for CURRENT sub channel
    -Added "HDTITLE" label, returns title for CURRENT sub channel
    -Added "HDTRACKNAME" label, returns "artist - title" for CURRENT sub channel
    -Added "HDTRACKNAMEx" labels (x = 1 to 6); example: "HDTRACKNAME1" returns "artist - title" for HD1
    -Added Prevention in CheckResume if VideoON
    -Added Ddisplay # to vista input enumeration; example: SOURCE: Playback Input line #1: "Front Green In"
    -Added "SCREENSHOT" skin command; example: "SCREENSHOT;filename.bmp" or "SCREENSHOT;$picspath$mypic.bmp"
    -Improved EVAL command so strcomp can have a label code as the 1st parameter
    -Improved SAVETOSKIN works with ++ (to work as ||)
    -Fixed built-in Gamma State after resume
    -Fixed for hibernateaware=false only working once
    -Fixed incorrect effect on sliding into folders
    -Fixed "SETPATH" will now work with paths with no files in them
    -Plugin Manger, find / load sequence, plugins are found and immediately loaded, vs find them all, then load. It fixes a technical back end issue. there should be no noticeable change.
    Notes:
    -Thanks to Mitch and BlueZX3 for continuing work on this project.
    -It is RECOMMENDED to always use the Installer to update the software, it has the newest config and skin tools included.
    As always you can download it for FREE HERE
    Thanks for your support,
    Guino.
    IMPORTANT: a small bug has been found in RRCONFIG, the winamp path if not set to auto it will be corrupted
    edit rr.ini manually or just use AUTO
    winamppath=
    when set with NO path, its in AUTO mode, and RR will find winamp based on the winamp developer's recomendation to find winamp on a system
    -Mitch
    Ride Runner RR's Myspace
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    SCREENSHOT = yes!
    Thx for the hardwork.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2007
    Germany
    Quote Originally Posted by guino View Post
    Thank you for the work! Great Program with great Programmers!
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    great news thanks guys..
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Broke something on Win7
    Installed the newest today on my Win 7 system, used the full installer, right over the top of my current config using DFX4.
    Anyway when starting up , RR has no control over winamp, I have to open the agent and press play on winamp, after that, RR has control over winamp.
    Still playing around with this any thoughts or suggestions?
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
    MySQL Error
    Oct 2004
    Dave, offically, we're not supporting win7
    we have to do a major rewrite to RR, to fix alot of file location issues
    (this is why its not UAC compatible)
    just for vista
    and since win7 and vista are close sisters
    but in any case, nothing drastic is changed in this version of RR
    so if u got a win7 issue, welcome to keep it in its own thread... but for me to look at the issue, it has to happen on vista too
    cause i only got win7 on a virtual machine
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mar 2004
    Greenacres, WA
    fine,
    just letting you guys know something that used to work is now broke.
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Winamp Automatic/Manual
    I noticed that I had to change the Player Setup setting for Winamp in RRCONFIG from Winamp(Manual) to Winamp(Auto) for the players path to show after running the installer. This is the first time I have had to do this after an update.
    ...JJG
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is because the config was finally updated. If winamp was installed prior to the running of the config, it will look to see if it can locate winamps path, other wise it will set itself to manual or if you previously spec a path.
    This rr version also has the same feature built in, if your using the wa as the player.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Dec 2007
    Washington, USA
    I was thinking that this was DaveDogs issue with his install...
    Winamp would not load with RR till I changed this, which made sense, Path was just "Winamp".
    ...JJG
  1. RR 03-10-05 - Few things..
    By guino in forum Road Runner
    Last Post: 03-11-2005, 02:16 PM
  2. RR 2-19-05 .. little things..
    Last Post: 02-20-2005, 01:55 AM
  3. Two things with RR 2-19-05
    By Passe in forum RR Bug Tracker
    Last Post: 02-19-2005, 03:02 PM
  4. Couple of things to get rid of
    By Adam F in forum Classified Archive
    Last Post: 02-16-2003, 02:11 PM
  5. Couple Things FS
    By Foobar in forum Classified Archive
    Last Post: 01-31-2002, 05:05 PM
