I haven't been able to get Ride Runner to run correctly after using the new install. The splashscreen for my skin shows then I just get a thin black line on the screen. I can see that RR is running on the task list. Any ideas?
Ride Runner RR's Myspace
Jeez, we haven't had that one for ages.
Missing background , background path incorrect or missing graphic file.
MJO, its all in the debug
3/7/2009 3:21:51 PM: LoadSkin: C:\Program Files\RideRunner\Skins\DigitalFX 4.0\
3/7/2009 3:21:51 PM: Plugin Manager: loading SkinDir Plugins...
3/7/2009 3:21:51 PM: Plugin Manager: loading SkinDir Plugins Completed.
3/7/2009 3:21:51 PM: ERROR loading image file(s) for: menu.skin
is that path right to ur skin? is menu skin images there? (likely not, since u got the ERROR..)
let me guess u install dfx4 and its in "Road Runner" Dir (just a guess)
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
The path is correct and the skin images are there (menu_OFF.png, menu_ON.png). Is it possible there is some dll that isn't registered correctly or something? I am getting the same error with the default carwings skin. Also, when I goto my old Road Runner directory and try to run I get that same problem, even though it was working prior to the install.
thanks.
actualy that error can be GENERATED from alot of different reasons
if a bitmap fails to create
which if fastmode = -1, could be GDI issue
which there is gdi, dlls
you did use the installer right?
if so that dll would be registered
GDIPlusWrapper.dll
AND u have to have GDI+ on ur system, which it IS in normal XP
but if u "lite"d the os...
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
FYI
the Microsoft dll is
gdiplus.dll
which i do stick in the RR dir
but it prob already is on ur system
in system32
ALSO WinSxS (Side by Side) should handle this
and the correct dll should load
UNLESS u delete, or messed with WinSxS
u can delete the gdiplus.dll in RR dir, it shouldnt ever be used anyway (prob could elim from installer)
(NOT GDIPlusWrapper.dll, that IS BEING used)
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
yes, i was about to post
i unregged my wrapper
and it did the same
i dont see how the registration failed, if u used the installer
unless U RAN the uninstall on another directory!!!!
like u installed it twice, then uninstalled one of them!!!
that would cause the .dll to be unregged!!!
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
