The keyboards in Ride Runner are part of the skin, so the person developing the skin would need to add those letters.
What skin are you using?
Just wondering where is alphabets öäå, is it possible add to RR?
I use Robby's BMW E36 skin and I try to change letters in skin file but it not work that way. I also check Ericsson GA628 font file and there is those letters.
As he said, this is something that needs to be changed in the skin file or you can make a new keyboard skin that includes the characters you need. For instance:
K02,062,191,059,078,001,233,201,"é","é"
The "é" is a representation of the character (So RR knows it's just a letter), the first number (233) is the ASCII code of the character in lower case, the second number (201) is the ASCII code of the character in UPPER case -- so changing the character in between the quotes doesn't really do anything other than reference (in the .skin file) which character you're changing in the keyboard. In regards to what appears in the skin, this is basically the same as any button, which means the images would have to be changed with the desired image for each button, OR the skin would have to define a label to be displayed over the button.
Ride Runner RR's Myspace
Ok, now I get it to work. Good guide is like half way done. Thank's Guino
