Results 1 to 9 of 9
Thread: can someone make me a XP HORM image
    MySQL Error
    Oct 2004
    I want to set up a vmware virtual machine
    i dont really know how to build a HORM
    but if someone can, then use vmware converter to make it a virtual machine
    i can add it to my testing setup
    i dont really understand it
    what i think it is, u set up the system how u want it
    and that becomes the horm, and any changes post the setup
    are tossed on next resume
    so it always resumes the same
    except some area of files?
    i need edumacation on this
    thanks
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I'm sorry Mitch but asking for a XP HORM image is too close to asking for warez, which is frowned upon on this forum. I suggest you rephrase your request before someone else does.
    This is a friendly warning, don't let it need be an official one.
    Aug 2004
    Germany
    Creating a HORM system isn't that difficult. There's an excellent HowTo on this forum, but here's what I've written in short:
    Code:
    Installing EWF and HORM:
    Rename: C:\ntldr to C:\ntldr.bak
    copy  : ewfntldr file to C:\ntldr
    copy  : ewfmgr.exe to C:\Windows\System32
    copy  : ewf.sys to C:\Windows\System32\drivers
    delete: C:\Windows\bootstat.dat
    create: C:\resmany.dat
    Open RegEdit
    Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root.
    Right-click on Root and click ‘Permissions’. Set ‘Everyone’
    register ewf.reg
    The reg key is attached (remove txt extension)
    The important commands for using EWF and HORM:
    Code:
    Commands:
    Enabling EWF (drive will be protected after a restart): ewfmgr C: -enable
    Disabling EWF (immediate, current changes will be safed): ewfmgr c: -commitanddisable -live
    If you also wish to use minilogon:
    Code:
    Installing MiniLogon:
    Rename: C:\Windows\System32\winlogon.exe to C:\Windows\System32\winlogon.bak
    Copy  : minlogon.exe to C:\Windows\System32\winlogon.exe
    Make sure that the new MinLogon  file isn’t replaced by Windows File Protection
    register minilogon.reg
    Again, reg key is attached (remove txt extension)
    The required files (ewf.sys, ewfmgr.exe, ewfntldr, minlogon.exe) are found in this iso:
    http://www.microsoft.com/downloads/d...displaylang=en
    THIS IS JUST THE FILTERED INFORMATION FROM THIS THREAD:
    http://www.mp3car.com/vbulletin/winn...tructions.html
    Attached Files Attached Files
    Jan 2009
    Subscribed
    MySQL Error
    Oct 2004
    konrad, thanks... ill see if i can do it, can u provide me with direct help
    PS Win XPe is avail as 120day eval
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    konrad, is these instructions, based on starting with a normal XP? or XP Embedded?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2004
    Germany
    Quote Originally Posted by mitchjs
    Doesn't matter as you just need the mentioned few files. Uploading them somewhere would be illegal, so you have to download the whole iso.
    You start with a normal XP installation. When you're finished you add the required files from the XPembedded-ISO.
    MySQL Error
    Oct 2004
    WOW... ok, thats what i wanted to hear
    now can u tell EWF what directories are writeable? commited at lease
    im a little confused, on what data i want protected, and such
    i dont fully understand all this horm stuff, i get the concept
    maybe u can help me privately
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2004
    Germany
    You can protect partitions or drives, not individual folders.
    I have two partitions on my CarPC.
    C:\ SYSTEM
    D:\ DATA
    C:\ drive is ewf protected, so I can use HORM (I don't shutdown the system or hibernate, I just cut power. Because of EWF and HORM the system will still resume)
    D:\ drive is NOT protected. Here I store my music/videos aaaaaaand RideRunner. I can add music and videos without disabling EWF.
    What you have to do:
    - set up the system as you wish (i.e. XPort, RideRunner, NavSoftware... in autostart)
    - enable ewf. After a restart the drive C:\ will be protected
    - restart the system
    - after everything is loaded, hibernate. Then the permanent hibernate file will be created.
    You can now cut power of the pc and it will still resume from the protected hibernate file. No need to shutdown or hibernate.
    -You want to change something on the system partition ? Disable EWF, make your changes, then reactivate ewf as described.
    -You want to add music or videos ? No need to disable EWF. Because D:\ is not protected, you can simply add music or videos to this partition and it will be available in RideRunner without the need of disabling EWF.
    -You want to change settings of RideRunner ? RideRunner is on the unprotected drive D:\, so you can make your changes without disabline EWF. You'll have to create a new hibernate file, though. Restart the system and press F8 to interrupt loading the fixed hibernate file. Boot the system normally instead, so RideRunner loads with the new settings. Then hibernate to create a new fixed hibernate file.
  1. Make a backup image of hard disk
    By hari-bhari in forum Centrafuse
    Last Post: 07-08-2007, 11:15 PM
  2. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 08:39 PM
  3. article on how to make XP boot up faster
    By blaster in forum Software & Software Development
    Last Post: 03-02-2005, 08:26 PM
  4. Best Software to make an identical image?
    By ZenerDiode in forum Software & Software Development
    Last Post: 02-27-2005, 03:07 PM
