Results 1 to 10 of 12
Thread: Album art enbeded into ID3?
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    So i've been trying to find a front end actually still supported to switch to from Frodoplayer but I always seem to run into something that keeps me from wanting to switch, tried installing Riderunner however I can't seem to get it to properly work with album arts embeded in the ID3 tag and that's how I have my library set up cause that's a standard among any MP3 player out there including winamp which Riderunner uses, but I can't get it to work, I even tried the plugin for it but no go, well it partially works, but not fully, seems to only work when every file in the folder has the same album art, if each song has it's own like NIN The slip for example it doesn't, is there any way to get this to work correctly?
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    the skin that you are using has a lot to do with this,also you said that you tried the mp3Art plugin, to use the plugin is a matter of registering the dll, then use "AlbumArt" indicator, thats all, latest version has been improved and updated for RideRunner and RoadRunner.
    Dec 2004
    Massachusetts
    Right now i'm using the default skin (Carwings_Dynamic) and I did register the dll and it does show up as enabled in the plugin manager.
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    That's how I just added my album art, and I'm running DFX4 on RR.
    Dec 2004
    Massachusetts
    I did try DFX4 but didn't have much luck with that either, it wouldn't even build the music database actually.
    MySQL Error
    Oct 2004
    Quote Originally Posted by shiltz View Post
    carwings doesnt use indicator "albumart", at least i dont think it does
    u have to customize now!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Dec 2004
    Massachusetts
    How exactly do I go about doing that? the thread with the albumart plugin didn't say anything about customizing, just registering the dll and enabing the plugin. Carwing does use albumarts as well, but only as a jpg in the folder, if that's what you ment by not using it.
    MySQL Error
    Oct 2004
    its done with an indicator
    someone who can skin can help you...
    but that image on the audio_player.skin and on the menu.skin, is not
    and "albumart" indicator
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    EL CAMINO's Avatar
    Jul 2005
    you can use the skin editor or even notepad can help,
    i.e. open "audio_player.skin" an look for a line like this,
    Code:
    I,632,81,165,169,"AlbumArt"
    RR is a great Front End, and to get the most of it, you need to understand the basics about customizing it. if you want to get this working right out of the box try another skin(you will need to go over the installation process), there are a lot of nice skins out there, not just 2 or 3, give them a try, and good luck.
    MySQL Error
    Oct 2004
    you know what
    J command will pickup the albumart!
    it falls back to if no picture mentioned to use albumart
    no need to edit skin
    just drop mp3art, into plugins dir (to be nice in its own dir)
    and register it...
    done
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Full album art with AAC (M4A) format in CF 2.0
    By vqstatesman in forum Centrafuse
    Last Post: 11-19-2008, 11:08 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. More on Album Art (bug/feature request)
    By unlfrank in forum Freeway
    Last Post: 12-28-2006, 12:58 PM
  4. ID3 Tag Issues - Album Art
    By Jdot in forum Centrafuse
    Last Post: 10-27-2006, 11:27 AM
  5. album art in id3 causes improper read
    By hateeecs in forum CF Bug Reports
    Last Post: 09-06-2005, 01:34 PM
