Results 1 to 3 of 3
Thread: Can SELECT only a file NOT current folder and subfolder?
    Dec 2008
    I integrate the KMPlayer as video player. To select the video, I make a KMPLAYER_BROWSER.SKIN. However, when I use the 'SELECT' command, it add the current folder to playlist. Can I only select a file not the whole folder?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You'd have to look into the skin commands used for KMPlayer and see if you can add a command to add single files.. I would think you should be able to do it, but since this is a user-made integration (that I've never tested) it's hard for me to tell for sure. Chances are high that this should be possible.
    Ride Runner RR's Myspace
    Dec 2008
    It seems that KMPlayer shared same lib with winamp, so the command for winamp is appliable to KMPlayer, for example, PLAY,NEXT,PREV,LOSTLIST,etc...
    To open a single file, the code can be:
  1. RoadRunner with CD Changer mode
    By MatrixPC in forum Road Runner
    Last Post: 11-20-2006, 05:37 PM
  2. Windows File Folder Reconciliation
    By Wiredwrx in forum Off Topic
    Last Post: 10-13-2006, 04:47 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
