Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: winamp not resuming music on restart
  1. #21
    MySQL Error
    Oct 2004
    no
    just when RR has focus
    type
    "reboot"
    just use keyboard while RR in focus...
    and im not sure what the point is, if ur gonna restart ur machine, just close RR 1st
    i would, i want to make sure as many apps i can close are closed
    before i resart
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I have exactly same issue as americasfuture2 have. If I shutdown Windows when RR is on music doesn't resume on next time, but if I close RR before Windows then resume works. I try it with nlited and full Windows with same result. I have ATX M2 power supply which shut down pc when I turn ignition off and it starts pc when ignition turned on, so it's very frustrating to close RR before shut down engine.
    Specs: Latest RR, Winamp 5.13 and WinXP sp3.
  3. #23
    MySQL Error
    Oct 2004
    did u look at the registry key
    HKEY_CURRENT_USER\Control Panel\Desktop\
    'WaitToKillAppTimeout' value
    (the default should be 20000).
    clearly, its because windows isnt letting RR shutdown cleanly
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #24
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Or..his setup isn't set up correctly..
    I just got a M2 PSU my selft and use standby. What jumper settings are you using for you shut down mode on the M2?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #25
    MySQL Error
    Oct 2004
    **** THERE IS A ISSUE ****
    RRs Shutdown takes too long, and XP terminates it
    patience
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    edmond, oklahoma
    im using the p1900 for my power supply. the on/off is really simple on these things. it interfaces into the power button on my mobo to mimic pushing the power button. so whatever you have set to act when the power button is pressed happens just like pushing the button yourself. so it cant be anything to do with my power supply thats causing this.
    Gathering parts----99% (I'll always want something else, its never 100%)
    Learning Centrafuse
    First Actual 98 Blazer LT Install
    First 08 Aveo5 SV Install
    87 Fiero GT waiting
  7. #27
    Feb 2009
    Finland
    I use P1 which is 5sec + 1min autolatch and hard-off 1min (jumpers: on off off off) Power set up is ok and it works like it sould be.
  8. #28
    Feb 2009
    Finland
    Quote Originally Posted by mitchjs View Post
    Mine is 20000
  9. #29
    MySQL Error
    Oct 2004
    this could never of worked, would never of worked!!!!
    the problem is... and think about this
    when windows is shutting down, it tells applications to close
    the same signal that closes RR would could WINAMP
    so.. what happens, is 1, winamp closes, now RR cannot get where or what im playing
    so.. it CANT save valid resume data
    also... it seems RR takes some time to exit, XP would terminate this process short
    and winamp wouldnt close 100%
    so, i apoligize for thinking it could ever work... i just NEVER restarted/shutdown out side of RR
    or if i did, i would close RR 1st
    one solution, is NOT let the power supply shutdown windows, but get a trigger, and use that inside RR to shutdown
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #30
    Feb 2009
    Finland
    Power supply just send signal to motherboard power switch pins or connect those so I think this is busted.
  1. Replies: 16
    Last Post: 01-03-2009, 05:59 AM
  2. Music path, Playlist path, Winamp
    By tmar89 in forum Road Runner
    Last Post: 09-12-2006, 07:56 AM
  3. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 01:07 AM
  4. winamp music collection program??
    By jtk in forum Software & Software Development
    Last Post: 04-23-2003, 05:40 AM
