Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: winamp not resuming music on restart
  1. #41
    Mar 2005
    Atlanta, GA
    So, I just install over the current installation?
  2. #42
    MySQL Error
    Oct 2004
    u can...
    download the installer...
    and install
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #43
    Feb 2009
    I have problem :-( RR wont resume music.... it resume music where it left when I close just RR and reopen it again but as soon as I shutdown pc and use hibernete to load windows it resume the playlist that I was listen to when I made hibenete.....
    There is nothing impossible in the world :-)
  4. #44
    Feb 2009
    Even I went to RR configuration and changed the horm to disable but it still resume music!!!! I change it to my flash disk but RR doesn't make any folder or file in my flash disk. I remember few weeks ago when it was used to work find, there was a folder called Horm... its nor there now.
  5. #45
    MySQL Error
    Oct 2004
    if horm is enabled, when u SHUTDOWN, thats when the files are created
    u dont use HIBERNATE to use HORM, (only once to create horm image)
    i have said it many times... LOOK AT DEBUG.txt!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #46
    Feb 2009
    what I have done is that I made a hibernete image and every time I use SHUTDOWN to turn off pc instead of hibernete button, and when I turn on pc it use hibernet to load windows, is this what you said? and it resume the playlist that I was listen to when I made hibernete last week and automatically starts plays song where it left.
    Horm is enabled and horm drive is my flash drive, and did othere settings in RR.ini.
  7. #47
    MySQL Error
    Oct 2004
    DEBUG.txt!!!!
    look at it, it will show the entire horm process...
    use rrconfig, to enable, debug, and do a fresh one
    and attach..
    yes.. HIBERNATE ONCE, then its shutdown...and every restart it resumes that hiberated image...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #48
    Feb 2009
    ooops my bad!!! i didn't get what you meant by debug.... i got it just now, ok i will turn on debug and will attach it here.
  9. #49
    MySQL Error
    Oct 2004
    review it yourself too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #50
    Feb 2009
    okay i've got debug file here now. i have done these stuff in order so far:
    1-installed windows
    2-installed all softwares and drivers.
    3-configured RR and played some songs to test RR.
    4-enabled ewf
    5-ewf askd to restart. pc restarted.
    6-opened rr and play song.
    7-took off usb
    8-hibernet
    now when I turn on pc without usb pluged in, it plays the song that was playing on step 3. but when I turn on pc with usb pluged in, it plays the song that was playing on step 6.
    and if i change the song, it never resume it. it stuck with two songs... and whenever i turn on pc I should start changing songs.....
    5/23/2009 2:07:23 AM: Start -- Version: 5/1/2009
    5/23/2009 2:07:23 AM: OS Type: XP
    5/23/2009 2:07:23 AM: FileManager: FileMode = Legacy
    5/23/2009 2:07:23 AM: FileManager: mypath = C:\Program Files\RideRunner\
    5/23/2009 2:07:23 AM: FileManager: ProfilePath = C:\Documents and Settings\Default User\My Documents\RideRunner\
    5/23/2009 2:07:23 AM: Master Vol: Speaker/4
    5/23/2009 2:07:23 AM: GetLineControl Failed: 401
    5/23/2009 2:07:23 AM: No Treble Support
    5/23/2009 2:07:23 AM: No Bass Support
    5/23/2009 2:07:23 AM: No Master ON/OFF
    5/23/2009 2:07:23 AM: Source: Wave=&H1008/1
    5/23/2009 2:07:23 AM: Source: SW Synth=&H1004/2
    5/23/2009 2:07:23 AM: Source: CD Player=&H1005/3
    5/23/2009 2:07:23 AM: Source: Line=&H1002/4
    5/23/2009 2:07:23 AM: Source: Microphone=&H1003/5
    5/23/2009 2:07:35 AM: PLAYER: Winamp Version:
    5/23/2009 2:07:35 AM: DirectDraw Count: 1 - []
    5/23/2009 2:07:35 AM: No Phidgets interface detected.
    5/23/2009 2:07:35 AM: Plugin Manager: loading Global Plugins...
    5/23/2009 2:07:35 AM: Plugin Manager: Plugin Found: SkinTool
    5/23/2009 2:07:35 AM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    5/23/2009 2:07:35 AM: Plugin Manager: Plugin loaded (Global): SkinTool
    5/23/2009 2:07:35 AM: Plugin Manager: loading Global Plugins Completed.
    5/23/2009 2:07:35 AM: LoadSkin: C:\Program Files\RideRunner\Skins\506 v1.0R\
    5/23/2009 2:07:35 AM: Plugin Manager: loading SkinDir Plugins...
    5/23/2009 2:07:35 AM: Plugin Manager: loading SkinDir Plugins Completed.
    5/23/2009 2:07:36 AM: Plugin Manager: Warning Plugin MOVIETIMES does not support Enabled Method
    5/23/2009 2:07:36 AM: Plugin Manager: Warning Plugin MOVIETIMES does not support Initialize Method
    5/23/2009 2:07:36 AM: Plugin Manager: Plugin loaded (menu.skin): MOVIETIMES
    5/23/2009 2:07:36 AM: Plugin Manager: Error loading (menu.skin): RRGAS (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
    5/23/2009 2:07:36 AM: Plugin Manager: Error loading (menu.skin): RRExtended (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
    5/23/2009 2:07:37 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:07:37 AM: Enter Exec: False, menu.skin, , False
    5/23/2009 2:07:37 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
    5/23/2009 2:07:37 AM: Executing: RUN;C:\Program Files\RideRunner\wifi_man.exe
    5/23/2009 2:07:37 AM: Shell: "C:\Program Files\RideRunner\wifi_man.exe"
    5/23/2009 2:07:37 AM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    5/23/2009 2:07:37 AM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    5/23/2009 2:07:48 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    5/23/2009 2:07:48 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    5/23/2009 2:07:48 AM: Que Exec: True, menu.skin, "AUDIO", False
    5/23/2009 2:07:48 AM: Executing: AUDIO
    5/23/2009 2:07:49 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:07:49 AM: Enter Exec: True, audio_player.skin, , False
    5/23/2009 2:07:49 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    5/23/2009 2:07:49 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    5/23/2009 2:07:51 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||LOAD;Audio_Browser.skin", False
    5/23/2009 2:07:51 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||LOAD;Audio_Browser.skin", False
    5/23/2009 2:07:51 AM: Que Exec: True, audio_player.skin, "LOAD;Audio_Browser.skin", False
    5/23/2009 2:07:51 AM: Executing: LOAD;Audio_Browser.skin
    5/23/2009 2:07:51 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:07:53 AM: Enter Exec: True, audio_browser.skin, , False
    5/23/2009 2:07:56 AM: Que Exec: True, audio_browser.skin, "ONSCREENCHANGE", False
    5/23/2009 2:07:56 AM: Leave Exec: False, audio_browser.skin, ONSCREENCHANGE, False
    5/23/2009 2:07:59 AM: Enter Exec: False, audio_browser.skin, "ONDIRCLICK", False
    5/23/2009 2:07:59 AM: Que Exec: True, audio_browser.skin, "ONDIRCLICK", False
    5/23/2009 2:07:59 AM: Leave Exec: False, audio_browser.skin, ONDIRCLICK, False
    5/23/2009 2:08:00 AM: Enter Exec: False, audio_browser.skin, "ONBTNPRESS||SELECT", False
    5/23/2009 2:08:00 AM: Que Exec: True, audio_browser.skin, "ONBTNPRESS||SELECT", False
    5/23/2009 2:08:00 AM: Que Exec: True, audio_browser.skin, "SELECT", False
    5/23/2009 2:08:00 AM: Executing: SELECT
    5/23/2009 2:08:00 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:08:01 AM: Enter Exec: True, audio_player.skin, , False
    5/23/2009 2:08:01 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    5/23/2009 2:08:01 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    5/23/2009 2:08:08 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:08 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:08 AM: Que Exec: True, audio_player.skin, "PLAY", False
    5/23/2009 2:08:08 AM: Executing: PLAY
    5/23/2009 2:08:08 AM: Leave Exec: False, audio_player.skin, play, False
    5/23/2009 2:08:17 AM: Enter Exec: False, audio_player.skin, , False
    5/23/2009 2:08:17 AM: Que Exec: True, audio_player.skin, "ONSLDsongpos", False
    5/23/2009 2:08:17 AM: Executing: ONSLDsongpos
    5/23/2009 2:08:17 AM: Leave Exec: False, audio_player.skin, ONSLDsongpos, False
    5/23/2009 2:08:17 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:17 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:17 AM: Que Exec: True, audio_player.skin, "PLAY", False
    5/23/2009 2:08:17 AM: Executing: PLAY
    5/23/2009 2:08:17 AM: Leave Exec: False, audio_player.skin, play, False
    5/23/2009 2:08:33 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||LOAD;Audio_Browser.skin", False
    5/23/2009 2:08:33 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||LOAD;Audio_Browser.skin", False
    5/23/2009 2:08:33 AM: Que Exec: True, audio_player.skin, "LOAD;Audio_Browser.skin", False
    5/23/2009 2:08:33 AM: Executing: LOAD;Audio_Browser.skin
    5/23/2009 2:08:33 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:08:34 AM: Enter Exec: True, audio_browser.skin, , False
    5/23/2009 2:08:36 AM: Que Exec: True, audio_browser.skin, "ONSCREENCHANGE", False
    5/23/2009 2:08:36 AM: Leave Exec: False, audio_browser.skin, ONSCREENCHANGE, False
    5/23/2009 2:08:37 AM: Enter Exec: False, audio_browser.skin, "ONBTNPRESS||SELECT", False
    5/23/2009 2:08:37 AM: Que Exec: True, audio_browser.skin, "ONBTNPRESS||SELECT", False
    5/23/2009 2:08:37 AM: Que Exec: True, audio_browser.skin, "SELECT", False
    5/23/2009 2:08:37 AM: Executing: SELECT
    5/23/2009 2:08:37 AM: CheckResume: ResumeMusic=2 WasRadio=0
    5/23/2009 2:08:37 AM: Enter Exec: True, audio_player.skin, , False
    5/23/2009 2:08:38 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    5/23/2009 2:08:38 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    5/23/2009 2:08:43 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:43 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:08:43 AM: Que Exec: True, audio_player.skin, "PLAY", False
    5/23/2009 2:08:43 AM: Executing: PLAY
    5/23/2009 2:08:43 AM: Leave Exec: False, audio_player.skin, play, False
    5/23/2009 2:09:05 AM: Enter Exec: False, audio_player.skin, , False
    5/23/2009 2:09:05 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    5/23/2009 2:09:05 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    5/23/2009 2:09:11 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:09:11 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    5/23/2009 2:09:11 AM: Que Exec: True, audio_player.skin, "PLAY", False
    5/23/2009 2:09:11 AM: Executing: PLAY
    5/23/2009 2:09:11 AM: Leave Exec: False, audio_player.skin, play, False
    5/23/2009 2:09:14 AM: Enter Exec: False, audio_player.skin, , False
    5/23/2009 2:09:14 AM: Que Exec: True, audio_player.skin, "ONSLDsongpos", False
    5/23/2009 2:09:14 AM: Executing: ONSLDsongpos
    5/23/2009 2:09:14 AM: Leave Exec: False, audio_player.skin, ONSLDsongpos, False
    5/23/2009 2:09:18 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:18 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:18 AM: Que Exec: True, audio_player.skin, "VOL-", False
    5/23/2009 2:09:18 AM: Executing: VOL-
    5/23/2009 2:09:18 AM: Leave Exec: False, audio_player.skin, VOL-, False
    5/23/2009 2:09:19 AM: Enter Exec: False, audio_player.skin, "VOL-", True
    5/23/2009 2:09:19 AM: Que Exec: True, audio_player.skin, "VOL-", True
    5/23/2009 2:09:19 AM: Executing: VOL-
    5/23/2009 2:09:19 AM: Leave Exec: False, audio_player.skin, VOL-, True
    5/23/2009 2:09:19 AM: Enter Exec: False, audio_player.skin, "VOL-", False
    5/23/2009 2:09:19 AM: Que Exec: True, audio_player.skin, "VOL-", False
    5/23/2009 2:09:19 AM: Leave Exec: False, audio_player.skin, VOL-, False
    5/23/2009 2:09:20 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:20 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:20 AM: Que Exec: True, audio_player.skin, "VOL-", False
    5/23/2009 2:09:20 AM: Executing: VOL-
    5/23/2009 2:09:20 AM: Leave Exec: False, audio_player.skin, VOL-, False
    5/23/2009 2:09:21 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:21 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    5/23/2009 2:09:21 AM: Que Exec: True, audio_player.skin, "VOL-", False
    5/23/2009 2:09:21 AM: Executing: VOL-
    5/23/2009 2:09:21 AM: Leave Exec: False, audio_player.skin, VOL-, False
    5/23/2009 2:09:21 AM: Enter Exec: False, audio_player.skin, "VOL-", False
    5/23/2009 2:09:24 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXITMENU", False
    5/23/2009 2:09:24 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXITMENU", False
    5/23/2009 2:09:24 AM: Que Exec: True, audio_player.skin, "EXITMENU", False
    5/23/2009 2:09:24 AM: Executing: EXITMENU
    5/23/2009 2:09:26 AM: Enter Exec: True, exit_menu.skin, , False
    5/23/2009 2:09:26 AM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    5/23/2009 2:09:26 AM: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
    5/23/2009 2:09:28 AM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||QUIT", False
    5/23/2009 2:09:28 AM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||QUIT", False
    5/23/2009 2:09:28 AM: Que Exec: True, exit_menu.skin, "QUIT", False
    5/23/2009 2:09:28 AM: Executing: QUIT
    5/23/2009 2:09:28 AM: Enter Exec: True, exit_menu.skin, "ONEXIT", False
    5/23/2009 2:09:28 AM: Queued: "ONEXIT"
    5/23/2009 2:09:28 AM: Shutdown: (1)
    5/23/2009 2:09:28 AM: Shutdown: (2)
    5/23/2009 2:09:28 AM: Shutdown: (3)
    5/23/2009 2:09:28 AM: Shutdown: (4)
    5/23/2009 2:09:28 AM: Plugin Manager: ALL Plugins unloaded.
    5/23/2009 2:09:28 AM: Shutdown: (5)
    5/23/2009 2:09:29 AM: Shutdown: (6)
    5/23/2009 2:09:29 AM: Shutdown: (7)
    5/23/2009 2:09:30 AM: Shutdown
  1. Replies: 16
    Last Post: 01-03-2009, 04:59 AM
  2. Music path, Playlist path, Winamp
    By tmar89 in forum Road Runner
    Last Post: 09-12-2006, 06:56 AM
  3. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 12:07 AM
  4. winamp music collection program??
    By jtk in forum Software & Software Development
    Last Post: 04-23-2003, 04:40 AM
