Do you have RR config by blue zx3? if so look @ general page 2 towards the bottom it says"run road runner at this resolution?" or something close to that. choose your resolution. also make sure your desktop res is correct.
Hi, have been with problems to get run the RR on the Mimo 740 monitor, I cannot run RR at 800x480 that is the maximum resolution of the mimo 740.
I already try lots of setings, but always cut of in the bottom.
anything is missing me? any config that i should do?
Dino_Audi_A6
Car: Audi A6 Avant 1.9Tdi
CarPc: 80%
Software: 80%
Of course the general.ini's ShowHeight=480 setting in the skin folder.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
merlin, yes already try that, by default when using only the mimo monitor only shows that config 800x480, but in fact the RR dont runs at that resolution, because it cuts down in the bottom.
Blue, how I do that? in the INI variables?
or in the file general.ini's in each skin folder?
thanks guys
Dino_Audi_A6
CarPc: 80%
Software: 80%
Thanks Blue I figure outis working just fine.
Now I have other problem, I use Igo8 pc version in RR without igo zoomer, because I arrange a good resolution for Igo at 800x480, good image and very fast, the problem is integrate with some skins like elite and teknik with preload gps screens to be avaible to switch between Igo and RR, there any way to chance resolution in gps menu screen to be possibel to see all?
thanks again
Dino_Audi_A6
CarPc: 80%
Software: 80%
