Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 70
Thread: RR 04-01-09 ... Never to late.. (GET HOT FIX)
  1. #11
    Aug 2004
    Germany
    Um...I have one harddisk with two partitions. Partition 1 is the system partition, which is protected. Partition 2 contains music and videos and is unprotected. I don't see why RR can't save the information there.
    Also, I don't know why I should dismount a partition.
  2. #12
    Sep 2005
    Excellent news on the new release. Thanks guys. Can we have some more details on how the HORM support works please?
    Say I have RR running on my system drive which is protected by EWF, I'm assuming the HORM support means RR is still able to save resume data etc to a separate drive? is that correct? Would it cover stuff like music playback position for an external player?
    Thanks.
  3. #13
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    And some folks were asking a couple of months ago if RR was dead...
    Tremendous work guys!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  4. #14
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Good news! /DISCARDABLE seems to be working perfectly! Thx!
  5. #15
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by Konrad View Post
    The drive (aka volume) needs to be able to be locked AND dismounted before setting the HORM point to prevent the volume from being write cached to the hibernate file. If not, any changes to data on the drive will be lost and/or corrupt the drive because the data on the drive does not match what is in the cache.
    Windows has a handle on fixed drives (protected and unprotected) that prevents it from being locked and dismounted. Hence, the need to use a usb flash drive to save RR resume data. An external usb harddrive doesn't work either. Apparently, windows treats it like a fixed hard drive and can't be locked, as well.
    Quote Originally Posted by miraclemaker View Post
    Thanks.
    If RR can resume playback normally using your external player (i assume it's not winamp) on close/open of RR, then theoritcally, it can work just fine w/ HORM RR IF the resume information is being saved in the RR directory in an ini file. The RR resume data is saved onto the hormdrive specified in rr.ini.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  6. #16
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Zogg View Post
    Rubbish...Dare they actually think that we would let this die...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #17
    Aug 2006
    Sun Diego
    /DISCARDABLE is looking good.
    I've opened/closed the same skin file w/ the /DISCARDABLE parameter 50 times now w/ no unforseen events (i.e. RR disappearing).
    RR Dead?
    Hardly.
    Thanks guys!
  8. #18
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cheers RR team, just as i thought i was going to see this nag screen for the 1st time that everyone keeps moaning about lol
  9. #19
    Aug 2006
    Sun Diego
    This release's content:
    Added
    -All ONxxx Events now passed to extension plug-inís, read only fashion.
    So, how is this feature used?
    Can PIs use the ONxxx events to execute commands in RR? If so, how?
    Is it something simple like:
    Case "onsongstart"
    rrsdk.execute("dothis")
    Or am I completely off base here?
  10. #20
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Sal R. View Post
    Case "onsongstart"
    Yes, you would be correct. And at some point, pi's will be using the "onsktinstart" to get any skin setting(skin.ini). I've also added that to my RRMedia plug-in for the next release.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  4. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 01:27 PM
  5. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2004, 12:13 AM
