Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 70
Thread: RR 04-01-09 ... Never to late.. (GET HOT FIX)
  1. #41
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    can some 1 shed light on my debug for all my PI's i use (rr root Plugins folder)
    Plugin Manager: loading Global Plugins...
    16/04/2009 18:29:57: Plugin Manager: Plugin Found: Aw_Genie
    16/04/2009 18:29:57: Plugin Manager: Warning Plugin Aw_Genie does not support Initialize Method
    16/04/2009 18:29:57: Plugin Manager: Plugin loaded (Global): Aw_Genie
    16/04/2009 18:29:59: Plugin Manager: Plugin Found: MobilePhone(.NET) plugin found but will be unable to create (most likely NOT registered)[skipped].
    16/04/2009 18:29:59: Plugin Manager: Plugin Found: RRExtended
    16/04/2009 18:29:59: Plugin Manager: Warning Plugin RRExtended does not support Enabled Method
    16/04/2009 18:29:59: Plugin Manager: Warning Plugin RRExtended does not support Initialize Method
    16/04/2009 18:29:59: Plugin Manager: Plugin loaded (Global): RRExtended
    16/04/2009 18:29:59: Plugin Manager: Plugin Found: RRGrid
    16/04/2009 18:29:59: Plugin Manager: Warning Plugin RRGrid does not support Enabled Method
    16/04/2009 18:29:59: Plugin Manager: Warning Plugin RRGrid does not support Initialize Method
    just trying to find out if its me or i missed somthing, they all work to a degree some don't fully work now, as they all did before
    thank you
  2. #42
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The only one that would be not running is the mobilePhone one, hence the "[skipped]"
    All the other did load and its just stating that those particular ones don't support those new plug-in methods, and they should work as normal.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #43
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Thanks blue most of the pi's do work just some functions have
    Stopped working. Nevermind just have to wait again for the
    Aurthors to do their bit again.
  4. #44
    Aug 2004
    Germany
    @mitchjs:
    Never mind about the installer not working. Restarted the computer and it ran flawless. Don't know why it didn't in the first place. Sorry for that.
    Quote Originally Posted by mitchjs View Post
    ALSO u are a good canidate for the NEW PROFILE MODE RR!!!
    didnt u and i hook up with that?
    I guess not, my CarPC runs on WinXP SP2. Just my desktop pc is VISTA.
    I don't even know what the legacy/profile modes are for (in which readme can I look it up BTW ?)
  5. #45
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The profile mode is really how RR should have operated from the begining...basially it does NOT store any settings/data in the programs file folder,and uses a RideRunner folder in your doc's folder for storing all that info in. Normal correctly written apps use the Application Data folder under your profile to store such setting, but decieded that too many non comp users wouldn't be able to locate said folder(hidden by default) so we used the doc's folder for ease of use for all users.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #46
    Constant Bitrate almera's Avatar
    Aug 2004
    -New internal error message screen that requires no extra skinning ( Say bye-bye to the MJSG_MessageBox.skin )
    About this error screen, I have a missing skin file in the skin directory, the new feature showed the error screen as expected. But that error screen stays at the back of all other skins... Here is the screen capture
  7. #47
    MySQL Error
    Oct 2004
    almera, something in your skin, is telling a window to be topmost....
    and causing the error to get put behind...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #48
    Aug 2004
    Fixed, Thanks Mitch..
  9. #49
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Fix what? How?
  10. #50
    MySQL Error
    Oct 2004
    almera, its best even if trivial, to post your solution, you never know when it will help someone... or in this case save treetop777 from a complete helpless feeling, he prob is in fetal position on the floor
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 12:38 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  3. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 09:31 AM
  4. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 12:27 PM
  5. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-28-2004, 11:13 PM
