Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 70
Thread: RR 04-01-09 ... Never to late.. (GET HOT FIX)
  1. #51
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #52
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by mitchjs View Post
    almera, its best even if trivial, to post your solution, you never know when it will help someone... or in this case save treetop777 from a complete helpless feeling, he prob is in fetal position on the floor
  3. #53
    Constant Bitrate almera's Avatar
    Aug 2004
    just fixed the broken / missing skin files, I believe a script tries to display a popup window causes this.
  4. #54
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll have to do some more extensive debugging/tesing with the new error message screen, its only one version old, so kinks will be worked out as they are found.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #55
    Nov 2005
    As always.. great work
    A phidget plugin... who would want that junk
  6. #56
    MySQL Error
    Oct 2004
    Almera, do u use screen transitions by chance?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #57
    Aug 2004
    Mitch, screen transitions disabled.
    Edit:
    That's my mistake, I have a skin file copied from a visualization skin file. I forgot to change the exit button code from "VISU||EXIT" to "EXIT" on that skin. That causes the error screen
  8. #58
    MySQL Error
    Oct 2004
    K
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #59
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #60
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Pic Viewer
    I have problem with the picviewer screen:
    Code:
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,4,4,184,74,"SETPATH;$picspath$",""
    B06,614,4,184,74,"BACK",""
    /, I, x, y, w, h, Code;INDICATORCODES
    I02,200,93,120,120,"PICTURE"
    /, S, x, y, w, h, fore R;RGB, G, B,  back R;RGB, G, B,  folder R;RGB, G, B,  file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,332,93,266,236,252,116,000,000,000,000,253,84,000,253,116,000,253,116,000,000,000,000,TRUE,20,"Ericsson GA628"
    SD,00,03,30,30,"$picspath$","*.jpg;*.bmp;*.gif;*.png",FALSE
    IL01,DL,transparent.bmp,sel.bmp,1,70,50
    When the screen is loaded the current path isn't picspath as specified in the SD and the list is empty. If I press BACK button or SETPATH button it works.
    In the previous versions of RR I haven't this problem.
  1. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  4. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 01:27 PM
  5. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2004, 12:13 AM
