Results 1 to 7 of 7
Thread: Variable slider problem
    Dec 2008
    I defined a variable slider to display the volume of car headunit. Also, I can adjust the headunit volume by clicking the silder. Now, the problem is that the slider can display the volume well just before clicking it. Once click the slider, it will always stay in the position mouse clicked.
    I traced the ReturnSlider(). It was called but the slider just does not refect the ReturnSlider value.
    -- SKIN
    Code:
    S01,9,440,390,35,9,440,390,35,H,01,"vslider1\pointer.gif",013"$CAR_MASTER$",
    -- ExecTBL.ini
    Code:
    "ONSLDCAR_MASTER","SETCARVOL;$CAR_MASTER$"
    -- ReturnSlider() in RRExtension
    Code:
    Case "$car_master$"
        Dim level As Integer = carVolume.getLevel()
        ReturnSlider = Int(65535 / CarVolume.MAX_VOLUME * level)
    -- ProcessCommand() in RRExtension
    Code:
    If InStr(CMD, "SETCARVOL") <> 0 Then
       'here is code to control car volume
    Endif
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I believe that your ReturnSlider Case "$car_master$" is not correct. You are also mixing two different methods. If you are gonna use a Ext PI, then you don't need any of the variable stuff, as that is mostly for creating a custom slider in a skin and be able to use it w/o using an ext pi. You can also use the setSlider() in RRExtention as well which is called when you click the slider ie...
    -- SetSlider() in RRExtension
    Code:
    Case "car_master"
         rrsdk.execute("SETCARVOL;" & Value")
         totally NOT recomended!!, reuse code from setcarvol cmd or better yet make it a func and then both can use it to set the volume
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Dec 2008
    Yeah, it works well. Thanks!
    Dec 2008
    I have a little confuse about the SetSlider(). It seems that one click will invoke this method many times. The value in first call is correct, but the value in later calls has a value larger than 65535.
    Added a msgBox in this method. After one mouse click on the slider, the first message box showed value 17308 which is correct, but the next msg box showed value 83180
    Edit: SetSlider() works well, the code only execute once for one mouse click. Not sure why the msgbox comes
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I would suggest saving a log (and not showing messageboxes) to display the values returned. The value should never be more than 65536 -- this could be very well happening because of the messagebox (hard to explain but has to do with the position of the mouse after the first messagebox is displayed).
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Good call G!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Dec 2008
    Quote Originally Posted by guino View Post
    Thanks guino! you are correct.
  1. songpos slider problem
    By carputer1 in forum Road Runner
    Last Post: 05-16-2008, 05:21 PM
  2. DSATX problem, not power switch problem!
    By VThokieME in forum Power Supplies
    Last Post: 05-04-2008, 12:22 AM
  3. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 09:28 AM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  5. yet another frodo install with problems.
    By Marsupial in forum FrodoPlayer
    Last Post: 08-27-2004, 06:28 AM
