Results 21 to 30 of 40
Thread: XMPCR with RideRunner not working
  1. #21
    Jul 2006
    Is RR attached
    Don't see an attachment on your last email. I will unreg and re-reg it.
  2. #22
    MySQL Error
    Oct 2004
    no attachments
    no email
    i just private messaged you...
    asking you to join me on msn(windows live) so we can chat instantly
    and i can send you the file
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #23
    Jul 2006
    installing
    still installing live chat....
  4. #24
    MySQL Error
    Oct 2004
    Registy Secuirty issue: not administrator
    (working on it)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #25
    Jul 2006
    Working but I don't know how.
    I set permissions on the registry main keys and I was able to register the xmcomm.dll. Then I started getting MJS Gadgets for XM Radio Control Assembly is not registered.
    I re-installed several times with no luck.
    Then I copied in the files Mitch sent me to debug and it worked. I then renamed my old files back and it still worked.
    The only thing I can say to help others is to look for the XMComm.tlb file in the MJS Gadgets -> xmradio directory. This file will be created if the assembly registers ok.
    Thanks for all your help Mitch!
    Brian
  6. #26
    MySQL Error
    Oct 2004
    some how something changed your registry permissions, other issues might show up...
    dont use the debug build of RideRunner i sent you, it will bloat the hell out of debug.txt
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #27
    Apr 2007
    I am now getting the same "MJS Gadgets for XM Radio Control Assembly is not registered" error.
    I have been running XP and an older version of road runner for at least a year, closer to 2. I upgraded to win7 and everything worked great except my volume control. XM, GPS, everything except volume control in RR, it works using the windows slider controls.
    I figured I needed to go ahead an upgrade to riderunner, sept 09 version so I installed it. When I run it, regardles of the skin I use, i get the error aboive and my xm no longer works.
    I have tried the unreg & runmefirst.cmd and I get a types registered successfully message and it creates the .dll file and says teh type library was regsitered sucessfully as well.
    Any ideas?
    Chris
  8. #28
    MySQL Error
    Oct 2004
    reinstall riderunner with the downloaded installer...
    use carwings skin....
    and see what happens... the installer handles all registration...
    also unlrelated, make sur ur using the newest FTDI drivers (prob are..im sure windows7 downloaded them from windows update)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #29
    Apr 2007
    Thanks for the reply. I have tried that and gotten the same results.
    I renamed the original \riderunner folder to \riderunner.old, downloaded the latest version, installed it with the default features to the default location using the installer. Ran the initial rrconfig program and set the xm com port to where it belongs, used the carwings skin and got the same xm mjs gadgets not registered results error.
    I have also tried uninstalling riderunner, rebooting & re-installing it with the installer and gotten the same results
    I can check the ftdi drivers but that part seems to be working fine as win 7 sees the usb devices and the previous version of road runner accesses the xm mp3 usb adapter properly.
    Any other thoughts or things I can try?
    Chris
  10. #30
    MySQL Error
    Oct 2004
    well....
    since ur saying windows 7, unless u messed with with windows 7 standard setup
    i can only say .net issue
    make sure ur not net is up to date...
    http://www.microsoft.com/downloads/d...displaylang=en
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Working Destinator PN SDK !
    By celo in forum Map Monkey
    Last Post: 02-08-2010, 06:18 PM
  2. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  3. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
  4. XMPCR...is there any hope?
    By ccrobin in forum Centrafuse
    Last Post: 07-26-2006, 12:00 PM
  5. Direct Xm working as a XMPCR!!
    By KMorphosis in forum General Hardware Discussion
    Last Post: 10-07-2004, 11:37 PM
