Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: XMPCR with RideRunner not working
    Jul 2006
    Question XMPCR with RideRunner not working
    I have tried about everything I can think of. The XMPCR works with Roadrunner and SatAmp but not with Riderunner. I get no signal so I am guessing it is not interfacing. I used the installer, loaded the hot fix and registered xmcomm.dll.
    Has anyone got an XMPCR to work with Riderunner? What steps did you use to set it up?
    Thanks, Brian.
    Mac Mini, XP pro SP3
    MySQL Error
    Oct 2004
    if u use the installer...
    all modules will update
    Roadrunner shouldnt be on ur pc at this point...
    if its in another directory... dont try to register xmcomm.dll
    you will have 2 different versions!!!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    just install RiderRunner with the 4/1 installer
    set comport in rr.ini if not already set
    thats it there is no other that has to be done
    just dont register anything... its all done by the installer
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jul 2006
    I did use the installer
    Maybe I am missing something. Here is what I did:
    1. Uninstalled Roadrunner.
    2. Installed Riderunner using installer (double clicked on RideRunnerSetup.exe)
    3. Installed the Riderunner update.
    4. Ran RunMe1st.cmd (because XMPCR didn't work).
    5. Uninstalled Riderunner and reinstalled.
    6. Ran registry cleanup tool.
    When you say run the installer do you mean run msiexec.exe from the command prompt to install Riderunner?
    Thanks for getting back to me.
    Jul 2006
    I will try again
    OK, I will uninstall everything and try again.
    Thanks.
    MySQL Error
    Oct 2004
    1. UNINSTALL ROADRUNNER (if it was installed by some installer)
    2. INSTALL RIDERUNNER (make sure u select xm option)
    thats all...
    im assuming u saved all you're .ini files? rr.ini
    if not u need to reconfig
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    msiexec.exe HAS NOTHING to do with riderunner!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    oh, u know, u can turn on debugging, and XMdebugging...
    and read the debug.txt
    its kinda what i call SELF HELP
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jul 2006
    Still no luck - must be SP3
    Reinstalled:
    1. Uninstalled Riderunner
    2. Rebooted
    3. Installed Riderunner.
    4. Installed hot fix
    5. renamed xm.down.png to xm_down.png to fix error
    6. configured xm comm port.
    still no luck. I will look at some of the SP3 secuity settings. SatAmp and XM Satellite softeare works ok.
    Jul 2006
    Already Tried turning on debugging
    Already turned on debugging and didn't find anything.
    When I find the problem I will post it for others.
    Don't take anymore of your time with this.
    Thanks for the help.
  1. Working Destinator PN SDK !
    By celo in forum Map Monkey
    Last Post: 02-08-2010, 06:18 PM
  2. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  3. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
  4. XMPCR...is there any hope?
    By ccrobin in forum Centrafuse
    Last Post: 07-26-2006, 12:00 PM
  5. Direct Xm working as a XMPCR!!
    By KMorphosis in forum General Hardware Discussion
    Last Post: 10-07-2004, 11:37 PM
