Results 1 to 10 of 11
Thread: Sorting playlist by Title or Artist
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    I just upgraded my RR installation after leaving it alone for over a year and I have a problem. I have a player skin that sorts my mp3's by title or by filename (artist-title). It's worked for years but now it doesn't since the new version was installed.
    To do this, I set the "Title" in Winamp to be %artist%. Then here are two commands I have in my ExecTBL.ini file:
    "SORTARTIST","ACTIVATE;Playlist Editor||SENDKEY;^+2||PLFORMAT;%ARTIST% - %TITLE%||RELOADLIST||SETVAR;SORTEDBY;0"
    "SORTTITLE","ACTIVATE;Playlist Editor||SENDKEY;^+1||PLFORMAT;%TITLE%||RELOADLIST| |SETVAR;SORTEDBY;1"
    My player.skin has a button like this:
    B,78,347,82,86,"SORTTITLE||SWITCHBUTTON;5>>SORTART IST||SWITCHBUTTON;5",""
    Why would this stop working? When I'm in the Winamp Playlist editor and press shift-ctrl-1 or shift-ctrl-2 it sorts properly. Just that the changed list doesn't show up in RR.
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    MySQL Error
    Oct 2004
    well... i did a sort in winamp, and reloaded the list in rr
    and it showed up
    make sure u enabled METADATA READING support in winamp
    option 1 or 4
    now i dont know how to set those key sequences in winamp... dont see any options like that
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    ALSO for "ACTIVATE;Playlist Editor" you have to be using the CLASSIC SKIN or MODERN
    does NOT show up when its in BENTO
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by mitchjs View Post
    I'm using a skin I made myself a couple years ago. What's the specific reason why one skin would work and not others?
    MySQL Error
    Oct 2004
    WINAMP SKIN!!!
    and u didnt answer my question, on how to make winamp use that sequence
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2004
    Los Angeles Area
    Ah, yes, I'm using the Classic Winamp screen in version 5.34.
    If you're referring to what keyboard commands do the sorting, they've been around for a long time. Maybe newer versions don't do it anymore? They're documented in About Winamp | Keyboard Shortcuts:
    Code:
    Ctrl+Sh+1   Sort Playlist by Title
    Ctrl+Sh+2   Sort Playlist by File Name
    Ctrl+Sh+3   Sort Playlist by File Path and Name
    Ctrl+Sh+R   Randomize Playlist
    Ctrl+R         Reverse Playlist
    If I highlight the Winamp Playlist and press these keys, they work fine. If I have the Playlist set to show in Winamp, I can see it display for a second when I press the RR command button and it doesn't look like it has changed order. So maybe it's an issue with the sendkey not being received by the playlist editor rather than the refresh not working?
    [EDIT:] Hmm, wait a sec... I just noticed that the Winamp playlist window says "WINAMP PLAYLIST" instead of "PLAYLIST EDITOR". Maybe Winamp has changed that heading at some point which would make the ACTIVATE not work! I'll test this and be right back...
    MySQL Error
    Oct 2004
    damm, im on 5.52 and those keys dont work
    i can resort with clicking in there...
    i did check the windows names, and PLAYLIST EDITOR is NOT avail, unless in classic...
    but that is the problem... the window name, cause when i sort it in winamp, and reloadlist, it works
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What I see.. WA v5.31
    using wa classic skin,which is the one your supposed to use, Playlist window title is "WINAMP PLAYLIST", but using Modern skin, the win title becomes "PLAYLIST EDITOR"
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Mar 2004
    Los Angeles Area
    Thanks for all the help! It's working great now. It WAS the Winamp window title that had changed. I'm very surprised to hear that the sorting keys don't work in 5.52 (why would they take them out?). Have to make a note to never upgrade to that version.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Or maybe mitch forgot to take off his blinder's...IDK though, I have no reason to update from my current verion.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. How About...A Virtual CD Changer
    By chuckster in forum Road Runner
    Last Post: 09-23-2011, 03:03 PM
  2. Replies: 0
    Last Post: 03-03-2009, 07:47 PM
  3. Problem with ADD1 and Winamp playlist sorting
    By wysocki in forum Road Runner
    Last Post: 09-25-2007, 01:57 PM
  4. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
  5. sorting title and author with ID3's
    By ketchup318 in forum Road Runner
    Last Post: 08-31-2005, 09:36 AM
