Results 1 to 9 of 9
Thread: How to get/set VAR in plugin?
    Dec 2008
    My plugin has some vars which need to be kept when RR exit and restore when RR start. Here is my code, but it does not work. Any suggestions?
    Get the var value in New() of RRExtension
    Dim station As String = SDK.getInfo("STATION")
    Save the var to skin.ini in Finalize() of RRExtension
    SDK.execute("SAVETOSKIN;STATION;" + station)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, if you're defining station within the scope of New() or Initialize() it will not be available in Finalize(), you need to declare station in a global scope (i.e. first line of the class module) then grab/set the value of it with getinfo at any given time during the execution of the plugin (i.e. startup, initialize, etc). Just be sure to call execute with savetoskin BEFORE your plugin destroys the SDK object.
    Ride Runner RR's Myspace
    Dec 2008
    To debug, I pre-defined the STATION in skin.ini : STATION=10
    1) set a label code with "=$station$", the label display 10 which is correct
    2) call SDK.getInfo("STATION") in plugin, but it returns ""
    any wrong in my code?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by efun View Post
    SDK.getinfo("=$station$")
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Dec 2008
    Quote Originally Posted by Sal R. View Post
    yeah, it works now. Thanks a lot!
    Dec 2008
    Where to find the document about the SDK? for example, it's methods and parameters.
    Dec 2008
    Quote Originally Posted by guino View Post
    Hi guino, is there a good place to save the var just before RR shutdown? I don't want to savetoskin on every command. Puting code in Finalize() does not work. Seems that the SDK has been destroyed when calling Finalize().
    guino's Avatar
    Nov 2004
    Toronto, Canada
    All you have to is monitor the value, then WHEN IT CHANGES, issue a SAVETOSKIN command, that way whenever you exit, it's already saved.
    Dec 2008
    it is a good way to save the value. thanks!
  1. RR 04-01-09 ... Never to late.. (GET HOT FIX)
    By Blue ZX3 in forum Road Runner
    Last Post: 05-08-2009, 09:39 AM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
