Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Auto Dimmer
  1. #11
    Dec 2008
    Quote Originally Posted by sxtnitehawk View Post
    Here's a 17 step autodimmer using the FB photosensor with RRFusion. if you have a definite port for the photosensor, you can change $IN1PORT$ to whatever port number the photosensor is on... so it reads for example... ANALOG0RAW
    sxtnitehawk, thanks for your code. I will try this solution.
  2. #12
    Dec 2008
    Hope touchscreen manufactory can produce a product which allow software to control the backlight. I think the techique should be ready for this. For example, I used the thinkpad. I can use hotkey "Fn+Home or End" to adjust the brightness.
  3. #13
    Dec 2008
    I found a perfect solution. My car has a light sensor in the mirror, so I can set the dimmer based on the sensor value.
  4. #14
    Sep 2007
    Export, PA
    as long as that sensor puts out a 0-5v signal you can, yeah
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  5. #15
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i have my xenarc's brightness control wire hooked to my car's dimmer knob to automatically dim my backlight when the headlights come on. the wiring diagram is somewhere on this forum. the only issue with this approach is my car's dimmer knob goes from 0 volts at maximum brightness to 12 volts at the minimum brightness while the xenarc goes from 0 volts at max to 3.5 volts at min. when turn the knob too low, the xenarc backlight shuts off and i have to power cycle it to get the backlight back on. i'm sure there's a way to drop the output voltage of the dimmer knob but with resistors or something of the sort but i'm not quite sure how to do it.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. Replies: 222
    Last Post: 09-21-2010, 12:39 PM
  3. dynamix 816 auto vga input
    By bangumandoo in forum LCD/Display
    Last Post: 04-19-2007, 07:10 AM
