Results 1 to 10 of 15
Thread: Auto Dimmer
    Dec 2008
    Auto Dimmer
    How to auto adjust the brightness of the screen? Is there a hardware sensor to do this? if so, a plugin can be developed to make DIMMER auto control based on the value received from the sensor.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mitch has made a dimmer type app within RR its self, have a look at your documentation in the rr folder, it may not be exactly what your after but as an alternative
    Dec 2008
    Quote Originally Posted by carputer1 View Post
    It is a good alternative. but I think a ambient light sensor will give more automatic control.
    Sep 2007
    Export, PA
    use a Fusion Brain with a photosensor and the RRFusion plugin
    using the reading from the photosensor, you can automate the dimmer value.
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by sxtnitehawk View Post
    This is what i do. Course i wrote RRFusion so i'm a bit bias lol
    Live mp3Car Facebook Chat
    Sep 2007
    Export, PA
    efun, BlueZX3's plugin RRExtended now has a command in it that I've needed to create a true autodimmer. as soon as I have the code down, I'll post it here for you... You'll have to play with some of the numbers, but itll get you started. You'll need a Fusion Brain with a photosensor, but trust me, YOU WANT IT...the Fusion Brain will open up totally new doors you never knew existed
    Sep 2007
    Export, PA
    Here's a 17 step autodimmer using the FB photosensor with RRFusion. if you have a definite port for the photosensor, you can change $IN1PORT$ to whatever port number the photosensor is on... so it reads for example... ANALOG0RAW
    Code:
    "AUTODIM","BYVAR;AUTODIMMER;<<SETVARBYCODE;PSENSOR1;ANALOG$IN1PORT$RAW||DRANGE1"
    "DRANGE1","BYRANGE;$PSENSOR1$;964;1024;DIMMER;0<<DRANGE2"
    "DRANGE2","BYRANGE;$PSENSOR1$;904;963;DIMMER;10<<DRANGE3"
    "DRANGE3","BYRANGE;$PSENSOR1$;844;903;DIMMER;15<<DRANGE4"
    "DRANGE4","BYRANGE;$PSENSOR1$;784;843;DIMMER;20<<DRANGE5"
    "DRANGE5","BYRANGE;$PSENSOR1$;724;783;DIMMER;25<<DRANGE6"
    "DRANGE6","BYRANGE;$PSENSOR1$;664;723;DIMMER;30<<DRANGE7"
    "DRANGE7","BYRANGE;$PSENSOR1$;604;663;DIMMER;35<<DRANGE8"
    "DRANGE8","BYRANGE;$PSENSOR1$;544;603;DIMMER;40<<DRANGE9"
    "DRANGE9","BYRANGE;$PSENSOR1$;484;543;DIMMER;45<<DRANGE10"
    "DRANGE10","BYRANGE;$PSENSOR1$;424;483;DIMMER;50<<DRANGE11"
    "DRANGE11","BYRANGE;$PSENSOR1$;364;423;DIMMER;55<<DRANGE12"
    "DRANGE12","BYRANGE;$PSENSOR1$;304;363;DIMMER;60<<DRANGE13"
    "DRANGE13","BYRANGE;$PSENSOR1$;244;303;DIMMER;65<<DRANGE14"
    "DRANGE14","BYRANGE;$PSENSOR1$;184;243;DIMMER;70<<DRANGE15"
    "DRANGE15","BYRANGE;$PSENSOR1$;104;183;DIMMER;75<<DRANGE16"
    "DRANGE16","BYRANGE;$PSENSOR1$;44;103;DIMMER;80<<DRANGE17"
    "DRANGE17","BYRANGE;$PSENSOR1$;0;43;DIMMER;85<<"
    Jan 2008
    San Francisco
    I may be mistaken (apologies if so), but aren't all these solutions adjusting the brightness of the video output from the PC? I have been trying to dream up a way to auto-adjust the LCD screen backlight brightness so that I can dim it down at night. Otherwise, at night, even the black levels are too bright for my night driving eyes. Has anyone figured out how to interface the PC to control the LCD backlight?
    What I ended up doing in the interim was adding a skin function to turn off the VGA output from the PC, which (after a few seconds) causes the monitor to auto power off. However, the touch screen is still active (powered from USB) so I can just touch the screen to wake up the PC.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is a HW hack, not saying it can't be done...just that these SW approches are just easier, but def not better then what your asking bout.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Sep 2007
    Export, PA
    i agree, controlling the actual backlight would be better, but definitely a lot more complicated because not all screens work the same. especially when you get into LED backlit screens...now to create a better contrast ratio, they can force the led backlight to dim in different areas to make dark colors darker and light colors lighter...dont know if that's made it's way to the small VGA market yet, but i know it has on larger TV's...
    For now, the internal DIMMER system is the best you're gonna get unless you custom hack your hardware, which could get mighty expensive with trial and error
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. Replies: 222
    Last Post: 09-21-2010, 01:39 PM
  3. dynamix 816 auto vga input
    By bangumandoo in forum LCD/Display
    Last Post: 04-19-2007, 08:10 AM
