u could make a plugin
ill reread this later... i just got home from Disney World
Just a possible suggestion for the next release. It's cool and great that we're able to define our own custom commands in exectbl.ini, but we're somewhat limited to what we can create with them.
What about making it possible for us to create custom commands with passed in parameters?
For example. I want to have all 3 radios (FM/XM/Sirius) on 1 screen, with just 1 set of preset buttons for all 3 to use... When i go to save a preset, i dont want to have to use a byvar just to set a variable, then another byvar to run a SAVETOSKIN, etc... would be much easier if i just needed 1 byvar with a custom command that i could pass in the needed parameters to do what i need it to do...
For instance, for the presets, the ability to create this in exectbl would be AWESOME...
RADIOPRESET;<FM/XM/SR>;<PRESET NUMBER>;<PRESET VALUE>
Examples:
RADIOPRESET;FM;10;93.70
RADIOPRESET;XM;5;25
RADIOPRESET;SR;2;101
see what i'm getting at here? RR is the most flexible frontend out, but this would put it well over the top, giving users an even wider range of abilities...
was just a suggestion though, to which i'm used to my suggestions being turned down, so i'm not gonna hold my breath...lol
Planning: [|||||||||-] 90%
Purchased: [|||||||||/] 99%
Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
yeah i know ZERO programming....
except for PHP/HTML/MySQL, but that's not really programming...lol
asking me to write a plugin is like asking a rocket scientist to perform brain surgery......not wise, lol
Here's the process I had to follow to do the same as what the above suggestion would have done...
Button code:
@SETVARBYCODE;PRESETNUM;1||RADIOPRESET@
execTBL code:
"RADIOPRESET","GETPREFIX||GETPVALUE||SAVETOSKIN;$R PREFIX$PRESET$PRESETNUM$;$PVALUE$"
"GETPREFIX","BYVAR;ACTIVESOURCEID;<< <<SETVAR;RPREFIX;FM<<SETVAR;RPREFIX;XM<<SETVAR;RPR EFIX;SR"
"GETPVALUE","BYVAR;ACTIVESOURCEID;<< <<SETVARBYCODE;PVALUE;FREQUENCE<<SETVARBYCODE;PVAL UE;TRACKNUMBER<<SETVARBYCODE;PVALUE;TRACKNUMBER"
Look at chucks skin...HAHAH
That's nothing for just doing one thing...
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
On the latest versions of RR there IS a command (SETSOURCE) to switch the active source which would allow you to switch the source then use the preset command (which will work according to the source).
Ride Runner RR's Myspace
the "RADIOPRESET" i show above is just for saving presets to skin.ini
My bad (will teach me to read closely)... but you shouldn't even need byvar to do what you're trying to do... try the below:
Button code:
execTBL code:
"RADIOPRESET","SETVARBYCODE;PVALUE;FREQUENCE||SAVE TOSKIN;FMPRESET$PRESETNUM$;$PVALUE$",fm
"RADIOPRESET","SETVARBYCODE;PVALUE;TRACKNUMBER||SA VETOSKIN;XMPRESET$PRESETNUM$;$PVALUE$",xm
"RADIOPRESET","SETVARBYCODE;PVALUE;TRACKNUMBER||SA VETOSKIN;SRPRESET$PRESETNUM$;$PVALUE$",sr
i'm confused how that would work...
how would it distinguish between the 3 instances, since all 3 radios are on the same screen?
