This sounds like a problem with configuration and/or your hibernation settings, could also be a problem with the winamp version you're using. I'd make sure I have the latest RR, then try a different winamp version to see and then verify the hibernateaware= setting in RR.INI -- posting a debug.txt file of your hibernate process would be very helpful in determining the issue..
LinkBack URL
About LinkBacks
