Results 1 to 10 of 20
Thread: calling for help with code.
    Sep 2006
    i want to great my own gps speedometer. can someone tell me how to put it together? i can make my own graphic and art work. the issue is how to code it.what i need to make it work. how it done.
    thanks.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by Enforcer View Post
    Do you have any programming/coding experience?
    hopefully it's better than his english
    it's all in good fun, don't take it the wrong way OP
    but getting back on topic, there is a couple threads around here that talk specifically about what you want to do, there's even a guy that converted his analog dash to digital using 2 7" lcds, just search and you'll find them
    Sep 2006
    i know a little bit of coding and programing
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK if you want to do a speedometer that is digital then it is very easy, in fact if it is in roadrunner you can just use the speed label.
    However if you want to recreate the analogue dial type then you really need to use flash. In fact There are some flash speedometers already done for roadrunner.
    or can you give us a more detailed idea of what you want. Including pics seeing as you say you can do the graphics
    Sep 2006
    i am working on the graphic.
    Sep 2006
    here is the concept i made. you guy got the ideas i want to do. as i stated above. how do i code the gpss peed when the car moving the number goes up and gps lock and artist. its just a scratch. the final skin will be black back ground and things in it place perfectly.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You don't need to write any code for making this screen. You just need to make the graphics with the empty space for the speed/sat count and then learn how to use the skin editor. You'll basically be adding a label with the code "GPSSPD" and another label with the code "GPSSAT" -- you'll be able to choose the size, font and color for the label to display.
    To learn about the skin editor and skinning you should read those threads (it's actually very simple once you get the hang of it):
    Roadrunner Skinning Tutorial
    http://www.mp3car.com/vbulletin/rr-s...-download.html
    http://www.mp3car.com/vbulletin/rr-s...-3-7-09-a.html
    Ride Runner RR's Myspace
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I don't think 04wrx was aware that RR has built in GPS capability.
  1. My VB code for Elm interface! OBD2
    By infinkc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-29-2009, 11:22 AM
  2. unlock code
    By slrpro02 in forum Wireless Communications
    Last Post: 12-28-2007, 06:55 PM
  3. code tags.
    By Enforcer in forum Mp3car Forum Suggestions/Comments
    Last Post: 06-26-2007, 02:53 PM
  4. Head Unit 'code' - help!
    By Laidback in forum Car Audio
    Last Post: 06-10-2005, 09:53 AM
