Results 1 to 10 of 14
Thread: RR's Audio Output Device
    Mar 2008
    Is there anyway to change the audio output device of RR so it is not the same as the windows default sounds? I have searched and couldn't find anything
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that is highly dependent on the player you're using... if you use winamp, you can simply open winamp outside RR and select the output plugin and configure what device it will use in its configuration.
    Ride Runner RR's Myspace
    Mar 2008
    Thanks for the quick reply.
    Sorry, I should have been more clear. I have winamp etc going through usb dac(not the default device) but the sounds say when clicking buttons in RR or using the internal player go through the on board sound card (default)
    I need to change because I need all the sound from my PC to output through the USB DAC except the from Garmin Mobile PC, which doesn't let you pick the output
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The PLAYSOUND command in RR and the built-in video player can only playback to the default audio card. While there's no workaround for PLAYSOUND it isn't really a "necessary" function, but rather a cosmetic thing. For the Video player, you could switch to MPC which should allow you to select the output device (There are similar alternatives as well). If you use FFDShow, then you may be able to keep using the built-in player and select the device for playback in the FFDShow Audio settings.
    Mar 2008
    Rats, because everytime there is some sound from the default device it interrupts my alpine head unit (ment to be only the satnav directions)
    So best fix would be to mute RR and use MPC for videos?
    Whats the best way to permently mute RR in this situation?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR doesn't generally make sounds other than with PLAYSOUND and with the built in video.
    If you just setup RR to NOT use voice, and to USE MPC (Both in RRConfig), RR will never make sounds unless by request of a skin (only some do that) -- in which case you can normally prevent it by deleting/renaming the sound file that it uses to make the sound. That's all you should need to do to "mute" RR completely.
    Mar 2008
    OK
    Thanks for your help
    I wonder if there is a program that can replace the windows mixed and direct programs sound to a chosen device
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can probably make an application to switch the default device so that RR and other applications will use the selected device for playback, but other than that you'd probably need some specific driver integration..
    Mar 2008
    What sort of drivers are you refering to?
    I don't know any programing
    May 2008
    I haven't tried this myself but I found this program when someone was looking for something similar before.
    It should allow you to create a link which will change the default audio device before starting RR and (hopefully) change it back. That way, RR will be connected to whatever sound-card you need and the rest of the system keeps using the default.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 05:25 PM
  2. audio gateway no audio output
    By Jayorich in forum Wireless Communications
    Last Post: 08-05-2008, 11:57 AM
  3. bluetooth handsfree with audio output
    By diiirk in forum General MP3Car Discussion
    Last Post: 08-30-2007, 11:59 AM
  4. DirectSound device vs. Sound device
    By BerkeleyTiger in forum FrodoPlayer
    Last Post: 03-29-2006, 02:47 AM
  5. Computer audio output thru radio
    By Pokey in forum Car Audio
    Last Post: 05-25-2004, 03:49 AM
