Results 1 to 5 of 5
Thread: Changing Indicator variable to another name
    Jun 2008
    Is there a way to re-declare a indicator variable to another name?
    I am currently trying to rename a RM_1STAR indicator variable to use something like RM1STAR as the variable.
    I also want this variable to update the same way Indicators variables are, without needing to invoke a command to update the value.
    I not familier with setvar, byvar commands but they all seem to require some command to invoke the value update where indicators seems to always update.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use SETVARBYIND;RM_1STAR;RM1STAR -- this will set a VARIABLE called RM1STAR with the value from the INDICATOR code RM_1STAR. You should not need to have the variable updated automatically or even on any kind of frequency, you just need to update it right before you use the variable for something (with the command above). In any case, you can't update it "automatically" but you can update it on a TIMER if you need it to update a label or something without a command being executed.
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Maybe more information would also help....That is an indicator from my RRMedia plugin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2008
    Thanks but I got it working without needing to declare a new variable. But BTW I still like to know for future reference on how to declare variables using byvar,setvarby,set and so forth is there a refrence doc somewhere on using ride runner syntax?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, is called "Skin Commands.txt" and should be either located in your RR folder(older installs) or the "Documentation" folder in your RideRunner folder( newer installs).
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. set Keys combination for changing songs in CF
    By a__l in forum Centrafuse
    Last Post: 07-23-2007, 10:49 AM
  2. Lane changing cams...
    By juve021 in forum General MP3Car Discussion
    Last Post: 03-22-2007, 05:26 PM
  3. Changing MT fluid....my self?
    By sdashiki in forum Off Topic
    Last Post: 04-27-2006, 03:10 PM
  4. changing my BMV2 honda logo to a toyota logo
    By 8675309 in forum Road Runner
    Last Post: 12-14-2005, 12:14 PM
  5. Replies: 10
    Last Post: 08-12-2004, 04:45 PM
