Results 1 to 10 of 15
Thread: RR and Garmin Trouble
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Angry RR and Garmin Trouble
    I am having a hell of time getting garmin to stay on top when embedded in RR.
    I have my window name set to Garmin Mobile PC and have also tried CDP_WND_FIELD
    nothing seems to keep Garmin on top of RR when I press a play button or try to overlay the OSK.
    Wht the hell am I doing wrong...this used to work great...
    Dummy problem.. read last post
    New Age Garmin - Skin for RR
    Apr 2009
    Contrary to other applications, Garmin mobile PC create a new window each time you change screens. So, it means RR probably make the first screen topmost, but if you switch the screen by pressing the settings button for example, a new window handle is created, so RR don't make it topmost. I have seen this problem as I am in the process to disable the exit and minimize button for my own interface I am building and I had to hook the click on these buttons and I have to reapply the hook each time another screen is shown.
    Aug 2006
    West Allis, WI
    I did have this trouble in the past though. When I made the overlay for the OSK it worked great.
    Is anyone else having this trouble?
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    i'm using GMPC all the time with RR v10.10.08 and it embeds great - no issues changing screens ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    Aug 2006
    West Allis, WI
    THat's probably it. I am using the latest RR. 6.01.09
    LIke I said it has worked great in the past up until recently
    MySQL Error
    Oct 2004
    no changes to anything related to embedding apps.... that im aware of... its not roadrunner vs riderunner
    are u using the built in dimmer??? if so, turn if off..and see
    (prob not, but worth mentioning)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    West Allis, WI
    Seriously though, that is the only change to my setup in a long time (rr version change). Probably over a year.
    Aug 2006
    West Allis, WI
    Now when in the external_gps.skin if I click on music control buttons at the top of the screen GMPC ends up behind RR, but if I go back to the main menu then back to the external GPS screen then it reappears.
    Same with trying to use the overlay plugin. If I try to overlay the OSK on top of GMPC then I lose GMPC.
    Aug 2006
    West Allis, WI
    Sorry one last post, I have tried this on three different PCs. My desktop, a PC with a fresh install of windows and my carpc.
    Same issue on all 3.
    MySQL Error
    Oct 2004
    are u using the GMPC overy script??? (ElcosMenu.exe)
    that runs outside of rr you know
    why not post some screen shots, since im a bit lost
    like i dont know what "music control buttons at the top of the screen GMPC" really means...
    maybe put a example .skin to gether for me
    you know, i downloaded GMPC setup as trial...
    set GMPC on Carwings overlay works... kinda...
    its a bit buggy... prob needs work
    specially cause it might be looking for roadrunner windows
    and maybe slipping past the compatibilty.ex
    i might need to set it up in skin ur using...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. New Age Garmin - FINAL RELEASE 01OCT09
    By ThunderStick in forum RR Released Skins
    Last Post: 08-31-2011, 12:20 PM
  2. Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
    By monkeyracer in forum RR Skins
    Last Post: 12-16-2010, 10:46 AM
  3. Garmin Question in RR
    By Minoritydan in forum Road Runner
    Last Post: 12-24-2008, 07:24 AM
  4. Replies: 12
    Last Post: 09-23-2008, 09:09 PM
  5. Need help with RR and Garmin mobile pc
    By viagra in forum Road Runner
    Last Post: 05-26-2008, 05:55 AM
