First, this:
"TIMER","CANCEL",AUDIOMENU.SKIN,MEDIAMENU.SKIN
should be replaced by this:
"TIMER","CANCEL",MEDIAMENU.SKIN
(RR can only match one skin name per line/command in exectbl.ini
For debugging the skin flow, I would recommend looking at the debug log. If you can't figure it out, you should post a zip with your audio/mediamenu.skin along with any related entries of exectbl.ini AND (More importantly) a copy of your debug log while trying to perform the problem function -- then we can look at it.
LinkBack URL
About LinkBacks
