Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: HD Radio Line Level too high?
  1. #11
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by mitchjs View Post
    but i think its wide open in settings.txt in the RR documents folder
    hdvolume=0-90
    Sets default HD radio volume. Default is 75, range is from 0 to 90.
    mitch
    Can you change that value while RR is running or does it need to be set before RR is started?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #12
    MySQL Error
    Oct 2004
    before.... since its ONLY set when the radio is initially powered on...
    try to avoid changing it, its better to adjust you line in, only lower if u need to
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    does the winamp line-in plug-in ignore line-in levels of the pc by resetting them?
  4. #14
    Nov 2007
    I tried setting this in rr.ini, but it doesn't seem to have any effect whatsoever. I tried hdvolume=5 and hdvolume=75 and the sound level was exactly the same.
    What section of rr.ini does it need to be in? I tried [HDRadio], [Radio] and [Extras].
    EPIA NX15000G, OCZ 128GB 2.5" SSD, 1Gb RAM, 7" anti-reflective, transflective touchscreen, M1-ATX, HD-Radio, Bluetooth, GPS, WiFi, USB DVD+-RW.
  5. #15
    MySQL Error
    Oct 2004
    Quote Originally Posted by roflcopter View Post
    dont, know, u will have to experiment on that
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #16
    MySQL Error
    Oct 2004
    Quote Originally Posted by miatacarpc View Post
    hdvolume=xx
    can be anywhere u want in RR.ini...
    and it makes a HELL of a difference, at 50 is so LOW
    i dont think u mentioned anything about what version of RideRunner you're using... but its been in for quite some time
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Nov 2007
    Update
    I had to lower the hdvolume level to about 15 in order to stop the distortion. That seems really low, but it does work, so I know the issue is the line level.
    Thanks for everyone's help.
  8. #18
    MySQL Error
    Oct 2004
    good, the lower the hd radio is, the greater the noise floor would be
    ideally, hi output, low input
    but some pcs line in, specially if its a mic in, make sure the bost is off
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Distortion Switching From HD Radio to Music
    By Stay_in_Focus in forum Road Runner
    Last Post: 06-19-2009, 11:20 AM
  2. HD Radio Skin For BMV2
    By bratnetwork in forum RR Skins
    Last Post: 01-26-2009, 02:21 PM
  3. Open Source HD Radio for Computers
    By ioi8 in forum Hardware Development
    Last Post: 11-24-2008, 09:08 PM
  4. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 01:59 PM
  5. high level inputs and low level inputs, what does it mean?
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-28-2003, 10:51 PM
