Results 1 to 10 of 18
Thread: HD Radio Line Level too high?
    Nov 2007
    I posted this over in the General Hardware forum too, but I thought this might be a good forum to try.
    I'm using Mitch's HD Radio cable, connected to a Visteon HDZoom, and I'm seeing a huge amount of distortion when I switch to the HD radio line. The volume on the Line is loud, even with the Line volume slider down at "1" (out of 100), so I'm wondering if it's possible that the ouput of the radio is just too high.
    This is on Vista, using a Via NX15000G mobo, which has a VT1708A audio chip. I'm using SatAmp as my test app. (RideRunner has it's own issues, which we don't need to get into here). I know the issue is not the line itself, since I can connect up a portable CD player to the same line, using the same cables, and the sound is clear.
    I know that Mitch's control dll can set the output volume of the head unit, but none of the apps I've seen, including HDPCR, utilize this function. Is there a registry setting/config file I can create that would do this? I'm not really sure what to do now, Any suggestions?
    EPIA NX15000G, OCZ 128GB 2.5" SSD, 1Gb RAM, 7" anti-reflective, transflective touchscreen, M1-ATX, HD-Radio, Bluetooth, GPS, WiFi, USB DVD+-RW.
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    try adjusting your line in level on your pc...
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Nov 2007
    See Original Post. Line input volume on the PC in the Vista Sound Mixer is set at 1%. It seems like the line input is being overdriven. Also, there is no "Mic Boost" on the Line in, though it is on some other inputs, and I turned it off on those just in case.
    I'm not sure if this could be related to the floating ground issue with the RCA jacks on the HDZoom. I tried the grounding mod before, when I had a separate issue with sound quality due what turned out to be a bad header connection on the Mobo. But the mod seemed to create a ground loop, so I pulled it off. Anyone know if this could be related?
    Jan 2008
    Dartmouth, MA
    Have you tried measuring the voltage on it?
    Does the volume slider have any effect on the volume at all?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Nov 2007
    No, I haven't measured the voltage - I'll try to do that, though I only have a multimeter, so useful info might be hard to come by.
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by miatacarpc View Post
    Though I only have a multimeter, so useful info might be hard to come by.
    Whys that?
    Set the multimeter to measure volts, and measure the volts on the output of the HD radio. More volts = more volume.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    you can adjust the output from the radio in rr.ini . I cant remember the setting name but a quick search should find the result.
    ahhh.. here it is.. per mitch:
    as for volume... 1st lower your input gain on the line in via mixer control
    i would avoide at all costs lowering the volume of the hdradio, but it can be done
    its in the documentation that no one reads!!! (settings.txt)
    hdvolume=0-90
    Sets default HD radio volume. Default is 75, range is from 0 to 90.
    in RR.ini
    I believe mine is set at 65 and my line-in volume is at 40%
    Live mp3Car Facebook Chat
    Nov 2007
    thx, I'll give that a try tomorrow and report back. I tried searching, but didn't manage to find it. odd.
    Woodbridge, VA
    Blog Entries
    32
    it was buried deep in the 100 page HD-Radio thread. i cant blame ya
    MySQL Error
    Oct 2004
    but i think its wide open in settings.txt in the RR documents folder
    hdvolume=0-90
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Distortion Switching From HD Radio to Music
    By Stay_in_Focus in forum Road Runner
    Last Post: 06-19-2009, 11:20 AM
  2. HD Radio Skin For BMV2
    By bratnetwork in forum RR Skins
    Last Post: 01-26-2009, 02:21 PM
  3. Open Source HD Radio for Computers
    By ioi8 in forum Hardware Development
    Last Post: 11-24-2008, 09:08 PM
  4. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 01:59 PM
  5. high level inputs and low level inputs, what does it mean?
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-28-2003, 10:51 PM
