Results 1 to 10 of 18
Thread: same song after shut down why
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Hi all thanks for looking
    I have the latest version of RR and winamp (5.08 I Think)
    I have RR shut down the computer (Using a Opus 320)
    I have RR setup as shuffle mode but the same song starts playing after the computer boot up from being off.
    How do I get RR to change to a different song each time it is booted up?
    Michael
    Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Post up your rr.ini and debug.txt so we can see what RR is doing on startup...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Think that's Winamps fault...
    If you play a song in winamp, close it, and reopen it... It will start on the very same song, from the beginning. Even when random playlist is active.
    Aug 2004
    Germany
    That's normal behaviour of winamp. RideRunner restores the song position.
    You have to post your rr.ini and debug.txt
    Feb 2005
    Huntsville, AL
    Uploaded is my debug.txt & rr.ini.
    What I need to clearify is what I mean when the same song is playing after the computer starts back up.
    The same song keeps on playing from weeks ago. When I shut down the computer with a (different song that was currently playing) the song from weeks ago still starts up again.
    The funny thing is I was watching it start up today and the new song flashed in RR for a sec but the the old song started playing again.
    Michael
    Quote Originally Posted by Konrad View Post
    Attached Files Attached Files
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    Aug 2006
    Sun Diego
    how come all your audio associated paths are not set? Did you run RR Config during your setup?
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Maybe your resume.ini file isn't being saved properly.
    Have you tried deleting resume.ini?
    I had the same problem a while back, but what i did was switch to RRResumer which autosaves the resume.ini file every x seconds which is included in rrextended. Has worked perfect ever since.
    Could be a setting problem though..
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by Sal R. View Post
    Quote Originally Posted by TeamRSX View Post
    Maybe your resume.ini file isn't being saved properly. Have you tried deleting resume.ini?
    I looked through the config and I did not have the path set for the music dir & playlist dir. Set that up but that did not help. Everything looks setup.
    I am not sure why there is a lot of Failed: 401 in the debug.txt
    If I close RR after changing songs and re-open RR the correct song is playing. But then if I shut down the computer using Opus the old song starts playing again.
    I have not tried deleting the resume.ini. I don't think it can be that because I have had this problem when I was using Road Runner which was in a different folder.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    Aug 2006
    Sun Diego
    So let me see if get this straight.
    RR is playing a song
    You exit RR
    Re-open RR
    >and the last playing song is resuming?
    Next scenerio;
    RR is playing
    You "turn the ignition off"
    OPUS sends a signal to shut off PC
    PC shuts down
    Start up PC and RR
    >RR is not resuming last playing song?
    Feb 2005
    Huntsville, AL
    You exit RR
    Re-open RR
    Next scenerio;
    RR is playing
    PC shuts down
    Start up PC and RR
    Exactly..
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  1. Sorting problem with RR
    By kobaz in forum Road Runner
    Last Post: 04-25-2007, 10:02 AM
  2. Occasional Song List Hickup with XM
    By chuckster in forum Road Runner
    Last Post: 11-25-2005, 01:09 PM
  3. Next Song search problems
    By Ascension in forum FrodoPlayer
    Last Post: 06-18-2005, 11:44 PM
  4. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
