Results 1 to 3 of 3
Thread: RR volume control won't work
    Jan 2008
    So as the title says, the volume/mute buttons in rr dont work, also the vol % isn't displaying either.
    not sure if it is a related issue or not, but the master volume icon in my task bar has dissapeared also(I have set it to 'always show' in taskbar properties).
    I know i am doing something wrong, just can't figure it out-- currently I am using a virtual audio cable setup as my main output device in sound properties, which is sent to asio4all, and then sent to Console for audio processing, and then onto my usb creative X-FI.
    do I need to set RR to adjust the volume for the virtual audio cable?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sounds like a driver/install issue of your sound card. From your description, not even the Windows mixer is seeing your sound card -- which means RR will NOT see it either. You should re-install the original sound card drivers and verify your card works in windows (and RR works with it) -- this will prevent you from wasting time with a bad/damaged sound card. Once you've verified the sound card works as it was originally designed, THEN you can play with drivers and windows settings (for whatever reason you may want to do so). You can be sure however, that if the sound card isn't installed as a standard windows audio device (and has a standard windows mixer interface) that it will not work with RR's mixer. Still a plugin could possibly be made to control the volume of your device (if there's a way to do that).
    Ride Runner RR's Myspace
    Jan 2008
    I will try that. thanks.
  1. Replies: 0
    Last Post: 12-01-2008, 05:48 PM
  2. Volume problem with RR.
    By Outsider787 in forum Road Runner
    Last Post: 08-01-2007, 02:45 AM
  3. Replies: 5
    Last Post: 06-29-2007, 03:24 AM
  4. phoCo remote control w RR??
    By liquid_smoke in forum Road Runner
    Last Post: 08-01-2005, 02:42 AM
  5. volume control
    By JaxPt in forum Software & Software Development
    Last Post: 04-21-2005, 07:44 PM
