Results 1 to 6 of 6
Thread: OSK And Web Commands
    Oct 2004
    Israel
    hi all
    im kinda new to rr programming so bare with me
    im trying to make a bi-lang osk for the web browser ( english - hebrew )
    so what i did it to create another skin file which contains the other osk ( named osk2.skin )
    and put a button in both to load them ( currently "EXIT||APPOSK2" / "EXIT||APPOSK" )
    now i just need to figure out how to save the text entered in one osk and put it on the other osk when i call it
    lets say for example "abc" is in english
    and "xyz" is in hebrew
    i want to enter "abc" in the english osk then move to the hebrew osk and enter "xyz" and i want that both will appear..
    from my little understanding i think i need to use the "OSKTOVAR" and "OSKTEXT" commands but i can't figure out how to call the hebrew osk with osktovar command and how to get the text from the variable
    or those commands don't work in apps and ment only for general usage?
    any other way doing this?
    maybe saving the textbox text or something else?
    help would be much appriciated
    thanks in advance ,
    madboy
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, you are correct in that those osktoxx cmds are for general usage and aren't gonna be usefull towards the app osk..
    What i think you could do is use my "TxtBoxToVar" cmd from RRExtended plugin and then you could grab the text, exit the screen and load the other osk with the saved text for the other on thats in the var...
    "TxtBoxToVar;Textvar||EXIT||APPOSK2||OSKTEXT;$Text var$"
    "TxtBoxToVar;Textvar||EXIT||APPOSK||OSKTEXT;$Textv ar$"
    Using that cmd and those two lines on your osk swap buttons, should work.
    Just see my RRExtended Pluing thread. Hopefully you know how to add a plugin to RR, other wise post back and i'll give the downlow of it...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2004
    Israel
    working great thanks alot
    Oct 2004
    Israel
    oh i have 1 more question regrading your rrextended
    im using elite lite skin and i want to switch the mute button to volramper_dn/up ( like att )
    there is a indicator for "MUTE" and the button call for "MUTE"
    so what i did is changed the button to this command :
    "RRVolRamper_Dn;90;30||SETIND;!ATT;ON||SWITCHBUTTO N;3>>RRVolRamper_Up;90;30||SETIND;!ATT;OFF||SWITCH BUTTON;3"
    and the indictaor to "ATT"
    is that ok?
    i have vista here and it doesn't seem to do anything here
    and i can't test it on my car atm so i just wanted to be sure i got the right line
    thanks alot man
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Looks right..from memory anyway..too many features to remeber syntax of each cmd...
    But ya, there will be problems when using that in vista as the mixer part of the code came from rr before mitch added vista support. At some point, I'll probably ask/get mitch bout using the vista part in there as well so that it works across the board.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2004
    Israel
    thanks its working
    as for vista i don't think anyone will use vista for car-pc
    maybe windows 7 - this would worth the hassle
  1. Web OSK
    By Blue ZX3 in forum RR Plugins
    Last Post: 05-23-2009, 11:03 AM
  2. RR Freezes when using OSK in Web Browser
    By ThunderStick in forum Road Runner
    Last Post: 09-23-2007, 11:29 AM
  3. osk sends keys twice in web browser
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 10-03-2006, 01:46 PM
  4. OSK + IE not inputting value
    By Rosebud6 in forum Road Runner
    Last Post: 12-16-2005, 02:18 AM
  5. RR 03-19-05 .. Web Browser ..
    By guino in forum Road Runner
    Last Post: 03-23-2005, 03:04 PM
