Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: XM will not unmute after standby
  1. #21
    Low Bitrate scottgs's Avatar
    Feb 2006
    Knoxville, TN
    Also, my PC comes out of standby much quicker than I thought, about 2 seconds. However, in this debug file I just posted, the XM had continous power, it was never powered down. I put a DMM on the power line to watch it, and see if something strange was happening. I never saw anything unusual. The power for the XM box is the same as the PC, which is from the Carnetix PSU. To do this, I just reprogrammed the Carnetix dead-man to 72 hours.
  2. #22
    MySQL Error
    Oct 2004
    scott, a quick review shows everything is working fine
    the mute/unmute commands are being processed
    perfectly
    there is no problem in software here
    i would suspect signal strength, then suspect the tuner
    please do what i say....
    once it fails, STOP USING RR, and USE XMID!!!!!!!
    also after 4:44, and u said u got no audio, u didnt do what i said, go to mp3, then back to xm... (and that should be done after xm is running)
    and u didnt do what i said too, turn off XM CACHE!!!!
    i cant help you, unless you follow instructions....
    this at this point we need to go to IM... im on MSN... we can debug issue live
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #23
    Feb 2006
    Knoxville, TN
    I did do the switch from XM to MP3 after XM failed, but appeared to be working, at 4:42:48
    You are correct, I didn't turn off XMCache. I'll do that. I'm trying to find XMID on your website. I couldn't find it last night, but I think I was too sleepy. I'll try to get you on IM. I've been outside trying to get it to fail again. when I took the PC pack out to the car, after downloading the debug, the XM audio came back.
  4. #24
    MySQL Error
    Oct 2004
    boy it does sound like signal isssue... and turing off XMCache might help u see that
    here
    http://www.rush2112.net/index.php?in...y_view&iden=16
    u said it wasnt working at 4:42...ugh... this has to go though IM
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 42
    Last Post: 12-11-2009, 02:36 PM
  2. Got XM to work, then it took a dump
    By DuDs in forum StreetDeck
    Last Post: 05-06-2006, 05:42 PM
  3. XM Channel Changes
    By Chuck in forum Road Runner
    Last Post: 04-05-2006, 04:33 AM
  4. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
