RR resumes the last used skin on the next startup -- this is saved to resume.ini... when changing skins in RRConfig it erases resume.ini so that the new choice is used on the next startup of RR. When you change the setting in RRConfig while RR is running, everything happens the same, but when exiting RR a new resume.ini will be created with your current skin, which means it will resume that skin (and ignore what's in rr.ini). Basically, you'd have to delete resume.ini before re-starting RR and for it to work. Otherwise the alternative is to use the skin browser or the setskin command to switch to the new skin while RR is running.
LinkBack URL
About LinkBacks
