It must not be embeding the first time correctly. RR first looks for the window name and if it can't find it then runs the loading parameter.
Hello, i try to embed one aplication in one skin, but i need that the aplication only run the first time, all other times only load skin and call aplication that load the first time.
In menu.skin i put this code:
"LOAD;DIGITALDASH.SKIN;!Afx:400000:3:0:6:db0a17;C: \DigitalDash\digitaldash.exe;!Afx:400000:3:0:6:db0 a17"
I need only call ONE TIME digitaldash.exe, because if i call again it load again and stop to work, how i can do that?
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Damn the problem with DigitalDash is that all time that you run it, change his autoit Class name....
First time: Afx:400000:3:0:6:770c37
Second time: Afx:400000:3:0:6:3fa20cd5
Third time: Afx:400000:3:0:6:b100713
etc etc etc...... never have the same
This program its good for know my time 0-100kph in my SRT-4 car, its easy to embed the first time, but only first time not more times![]()
use just Afx:400000:3:0:6: (the portion that never changes) as the window class..
"LOAD;DIGITALDASH.SKIN;DigitalDash;C: \DigitalDash\digitaldash.exe;!Afx:400000:3:0:6:"
Bear in mind that if you have anything else running with a similar window class, it may embed that window instead -- you should try to look for a window name as well, and if available, add it to the command to prevent embedding of the wrong window.
Ride Runner RR's Myspace
