Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 84
Thread: RR 07-01-2009 Release - Available NOW
  1. #41
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by carputer1 View Post
    i have just added the new label cmds ie VHCENTER, also VCENTER, i have labels over buttons cmds as you do , but useing this new label cmd makes my button not work,
    yet to try the other label cmds
    unfortunately, the new label alignments had to be placed in a new control (similar to the scroll label -- in fact, it is an improvement of the scroll label). This means that it will behave like a scroll label -- which you should be able to click (or at least I know we can add that), but to make a button behave normally (with the updates on images on/off/down) may not be possible, but I can research a bit on it.
    Ride Runner RR's Myspace
  2. #42
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cheers G , if you can make them clickable great , but useing it as a standard label on buttons would be even better , as when i tryed these cmds they worked alot better than WRAP-CENTER and CENTER, i use alot of WRAP in my skin but it dose not ajust to well when i use a different font where VHCENTER dose, cheers for looking into it more .
    your humble servant
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #43
    Jul 2006
    i just tried to upgrade from the previous release to this one using the installer and now every time i launch RR i get a windows installer popup trying to install 4-5 different components for which it cannot find a certain file. after i hit cancel about 5 times, RR launches, but then the installer pops up each time i go back to the home screen. i am on the lsx void screen, using winamp, hd radio enabled. any ideas?
  4. #44
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    "i just tried to upgrade from the previous release..."
    June's? OS?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #45
    Jul 2006
    sorry, yes i meant June (or maybe May). Windows XP. anyways i uninstalled ride runner and road runner from the control panel, reinstalled my ride runner, and copied over the old rr.ini. however now my folder structure is crogram files\road runner\ride runner. i have a feeling this whole renaming thing may cause problems down the road now that all the folders are different... :-/ anyways thanks for the quick response, all is working well for now.
  6. #46
    MySQL Error
    Oct 2004
    hari-bhari, you have a VERY VERY VERY old installation... of roadrunner on your PC
    I would backup ur rr.ini and favs.ini (if u got xm/sr) and your SKIN
    uninstall RideRunner...
    you should use the MSI clean up tool... there is a sticky
    and try to clean up the old MSI installation of RoadRunner
    (such a messy installer)
    Remove Older Installer MSI CLEANUP
    then re-install Riderunner, to c:\program files\RideRunner
    and drop your rr.ini in, and your skin
    tweak a bit
    and you should be good to go
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #47
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Unbelievable... you guys are still at it. What have I missed since '07. I think it's time for me to update my software.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  8. #48
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    So far, so good! thanks!
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  9. #49
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    I don't get it... where's the download? "Product Catalog", "Online Shop", and "Support" are all the same page and none of them have a download link.
    -InfinitiPC
  10. #50
    Sep 2008
    Western Australia
    http://www.nisuautomotive.com/catalo...php?cPath=2_22
    Click on buy now and go through the process
  1. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  3. RR 05-28-05.. Early Release..
    By guino in forum Road Runner
    Last Post: 06-04-2005, 09:36 PM
  4. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
  5. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
