Results 1 to 10 of 10
Thread: Unloading an embedded .swf when leaving the screen
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    This has been a problem for some time, and I have never found a solution to it.
    How do you close an embedded .swf when leaving a screen? I have tried:
    CLOSE|| on the button to leave the screen
    CLOSE||EXIT on the button to leave the screen
    Putting /DISCARDABLE in the skin with the .swf
    There has to be some way to do this properly....
    My Fiero Build Thread
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, the only way to destroy the flash control once created on that screen is to use the "/DISCARDABLE" skin option. G has talked about this before in a few diff places.
    Or to load the flash control with a dummy swf file. Ie... just an empty movie, which would take up less mem and cpu as its not really gonna be doing anything.
    One last way would be to use a var as the movie file name and set the var to nothing, do a reloadscreen, before exiting, that might work if you want to save the screen in mem...IDK?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If the embedded swf is embedded by the F definition, the only way to unload it right now is using /DISCARDABLE... we can add variable support so you can set the flash movie name in it and do a reloadscreen.. but there's nothing else that can unload a flash movie right now. Since we did some work to wrap the flash movie awhile back, it is now possible to unload the object (and flash movie) and reload it -- causing the effect of "unloading" a movie.. I can see if I can add that in for this coming release.. while RRConfig is still in the works..
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That was a sad to the blue man...
    I know...I know...I'm working on it as I type..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Just was looking at the source from today, WOW Guino you are fast! I see the Flash variable was added in already! Thanks!!!!!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by JohnWPB View Post
    I think it only works with the newest flash versions (or I would have made this feature before)..
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Before someone asks.... I only seen the Cmd(SetFlash) in the svn comments... Did/Could you add support for if a screen has more than one flash Ctrl, as there are some that have two to three. Not sure how you'd handle that, by order listed in skin file? As this will probably be the next request for this cmd...
    And Yes, I'm still on the Config...Should have a tester for mitch tonight...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Setflash already works by the order on the skin file... SETFLASH;1;logo.swf ... if you're talking about using the ID, then I'd have to check.. this forces to expand the Skin interface by adding functions to access the ID of the flash object, however the current implementation works the same as showflash/showlabel works. Are you looking for a "setflashID" or am I understanding this wrong ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, going by what you've said, sounds like you've already got it covered... I just wasn't sure and didn't check before hand on the actual usage/imp of it.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hahaha... I'm in no hurry man.. I think myself and everyone here appreciates your work on RRConfig.. so I would think most would rather wait a couple of days to have a nice way to config the new stuff than have to do it by hand..
  1. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. Replies: 4
    Last Post: 02-29-2008, 05:51 PM
  4. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  5. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 05:31 AM
