Results 1 to 3 of 3
Thread: problem with imageviewer
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    I'm having trouble displaying the image files names in imageviewer. When I open up image viewer I can see the directory list that contains the directories found in my photo path. When I enter a directory I cannot see the image file names (photo1.jpg, photo2.jpg...e.t.c). If I click on the view text then the images are displayed and if I press "s" for slideshow they are displayed one after the other.
    Is it like this (not to show the file name) or am I doing something wrong?
    I have the latest RR install and the problem is the same with imageviewer embedded into RR or as a standalone program
    The road is long but we are getting there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you're using GabePage's Imageviewer (2006), that is correct, it does not show individual file names, just folders and the images.
    RR has built-in picture viewer support for JPG/BMP/GIF and PNG files -- it does show a list of folders and files, just requires making a skin. The Imageviewer from GabePage has better zoom features though.
    Ride Runner RR's Myspace
    Dec 2003
    Thanks for the reply Guino. Actually I'm trying to use the built-in picture viewer. If I use an old RoadRunner install then I can see the photo file names. In my new RideRunner install I cannot see the directory and photo file names. The skin that is used in both installs is the same. In fact if I replace roadrunner.exe in the new riderunner install with roadrunner.exe for an old install then when I run riderunner the files show up correctly.
    This is really weird. Any ideas as to why it is doing this ?
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
