Results 1 to 10 of 12
Thread: RoadRunner not interfacing with winamp after clean install of Win7
    I had RoadRunner running great on Win7 RC but reinstalled with the latest RTM build I could get hold of and it's now broken. I reinstalled flash and winamp and after a hiccup where RR gave the error 'Unexpected error; quitting now' at startup until I'd launched it once as administrator, everything seemed like it was going to work. But when I go to play music in RR, nothing happens. It transfer me back to the music page but the track list remains empty and winamp doesn't start playing anything.
    I initially used winamp 2.95 but tried 5.13 (which was what I'd had with the previous Win7 install). Both installs were from installer still sat on the local disk from when I set up Win7RC.
    Anyone know what's going on?
    Switched to the latest RideRunner and it doesn't have this issue. But it has other issues...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Arathranar View Post
    Never heard of a "perfect" software ... in any case, RR must run with admin rights or some things just won't work, that goes for all: NT, 2000, XP, Vista, Win7...
    Ride Runner RR's Myspace
    That isn't the problem here though. The older RoadRunner still wasn't talking to WinAmp even if I ran it as administrator. The newer RideRunner can talk to winamp fine even if I don't run it as administrator. Very wierd.
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I also experienced problems after updating to Win 7 RC , It took several re-installs of RR, finally ran the installer in compatibility mode and things seemed to work, same with DFX4. Things are pretty much working now, but a few quirks here and there, considering going back to XP now that there is a new voice recognition plugin.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
    MySQL Error
    Oct 2004
    its not wierd.. its quite logical.. many improvements to RideRunner since, RoadRunner, including communictations to WINAMP
    use RideRunner, and all will be fine...
    on WIN7/(vista), set up the short cut to run as admin
    or turn off UAC
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    also no need to RUN the RideRunner installer in compatibility mode
    its already UAC Aware
    now... DXF4, is a messy installer. i prob wouldnt use that...
    that skins needs a big time refresh...
    prob if u run dxf4's installer as admin, it be ok
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Quote Originally Posted by mitchjs View Post
    True. But this is the exact same build of RoadRunner I was using successfully in the Win7RC install. Although thinking about it I've got a feeling I had this exactly problem when I was first setting it up then. I wish I could remember how I fixed it .
    The jury is still out on whether I'll switch to RideRunner. I'd coded up some nice improvements to RoadRunner to work with a custom skin (multiple variations on gps and video skins to enable you to move around in the UI and still see the video/gps and easily get back to the full view). I stopped using it when I needed a bug fix in a newer RoadRunner and found the code structure had change so much that my (somewhat invasive) changes were extremely hard work to port). But I was thinking of maybe starting over and re-adding that support. But that means I'm stuck with the old RoadRunner. Or alternatively I can scrap the fancy picture-in-picture style skin idea and build a new skin idea I've had that I think shouldn't require new support in the exe .
    MySQL Error
    Oct 2004
    maybe u can do all ur mods, in a Extension plugin... not sure what you got going, but there is just so many performance improvements in RideRunner...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Maybe. I've been away from the RR scene for a couple of years so it's all new to me .
  1. Replies: 5
    Last Post: 11-13-2006, 10:05 AM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  3. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 01:07 AM
  4. Winamp install gets corrupted randomly...
    By Chita79 in forum Road Runner
    Last Post: 06-02-2005, 07:41 PM
  5. Running RoadRunner and Winamp
    By MatrixPC in forum Road Runner
    Last Post: 02-09-2005, 09:07 PM
