Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: music not resuming after hibernat on RR (is killing me)
  1. #11
    MySQL Error
    Oct 2004
    there is no hibernation/resume sequence in the debug...
    so cant help ya
    i assume i already made your hibernation point...
    so... boot pc (its a technically a resume), use riderunner for a sec, power off your computer... also, if your power supply doent send proper signals to the OS, RR will never know your powering down)
    you do know once u create hibernation point, you DONT hibernate anymore
    you power on and shutdown...
    its on the shutdown.. that RR will create HORM files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Feb 2009
    is that can be because of SP3? Okay what I will do is that uninstall the XP SP3 and install XP SP2 and I will post the result here tho.
    There is nothing impossible in the world :-)
  3. #13
    Feb 2009
    I just installed XP SP2 and the main problem is solved now :-))))) :-D but there is a little issue there. when I turn off PC via RR, everything work flawlessly but when I use PC power switch or windows shutdown menu, it wont resume music. so it seems windows just cut off RR without notify RR so RR can not save settings.... any idea? had anyone same issue?
  4. #14
    MySQL Error
    Oct 2004
    windows shutdown menu, should give RR enough time...
    all the information is in the debug.txt !!!!!!
    you can see if it made it though bits of shutdown.. or if it was forced to exit
    one thing for sure dont mess with the windows default shutdown times (i forget the key)
    just to give u a faster shutdwon
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #15
    Feb 2009
    i can't have debug.txt cause ewf is enable there so after shutdown there wont be any debug there. but I know my windows has problem for sure!!! I installed ewf on XP pro. what I will do is that download XPe trial version from microsoft website and give it a try... i will post the result here tho.
  6. #16
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    did you try to play a song only in winamp and than hibernate, because it sounds more like a winamp problem than a roudrunner,
    try winamp plug-in resumer and / or playlist -autosave.
  7. #17
    Feb 2009
    yes I just did it and still no luck. I really don't understand why RR doesn't do its job when windows asks to exit.... but it does its job perfect when it closes it self.
  8. #18
    MySQL Error
    Oct 2004
    trying some things... but it all looks good here
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Why does RR always go back to music page on resume?
    By scottgs in forum Road Runner
    Last Post: 09-23-2007, 10:32 PM
  2. Empty music folders in RR
    By Outsider787 in forum Road Runner
    Last Post: 08-16-2007, 11:58 AM
  3. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  4. RR is slow when pusinh Music
    By Goose in forum Road Runner
    Last Post: 04-20-2005, 06:17 PM
  5. Music Not playing in RR.
    By ShawJohn in forum RR Bug Tracker
    Last Post: 03-22-2005, 07:28 PM
