Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: music defaults to first song on open
  1. #11
    Jun 2008
    You refer to this line I assume?
    "KillWinamp","RunQ;$skinpath$scripts\Kill_Task.exe |winamp.exe"
    Is there a way to change that to make it run the proper command to end the program rather than killing it? It's not a huge issue, it's just bothering me because I don't remember this happening with the old install
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by HoffR1 View Post
    Just change it to:
    "KillWinamp",""
    Under "NORMAL" circumstances, there's no need to kill winamp.
    Ride Runner RR's Myspace
  3. #13
    Jun 2008
    Thanks, that helped a lot. It only works now if I exit RR before I shut down the pc (shutting down without exiting still forgets the current track) but at least I have a way to preserve the track number
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    How are you shutting down ? power button ? shutdown option in RR ? I suggest you try different methods to see if it makes a difference.
  5. #15
    Jun 2002
    Virginia
    Bump - Same Problem Here
    I'm now having the same problem. I've been using RR with the DFX skin for years now and this has just started. Whenever I close RR and restart only the first song in the playlist that was loaded at the time of close will appear. I have verified that resume mode is set to always in RRConfig and that resumemusic=2 in rr.ini.
    I have now done fresh installs of both RR and DFX on two computers and it's happening on both. I have verified that resume works fine with Carwings, but it now does not work with DFX. DFX has not changed in over a year so it must have something to do with the new RR version and how it interacts with DFX. Any thoughts?
    I'll post this in the DFX thread as well.
    Thanks in advance.
  6. #16
    MySQL Error
    Oct 2004
    remove that winamp KILL!!!
    its bad, and NEVER should have been done
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #17
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by mitchjs View Post
    Well why is it in there then? Have you tested this yourself? What is it doing exactly?
    Tidder
    Try RevFE
  8. #18
    MySQL Error
    Oct 2004
    good question, its in the skin... only john who made the skin, can answer that
    what happens is, the winamp task it forced ended, and RideRunner therefore cannot get the last playing information
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Two ways...
    #1
    In the skins exectbl.ini, file find this line:
    "KillWinamp","RunQ;$skinpath$scripts\Kill_Task .exe |winamp.exe"
    and make it
    "KillWinamp",""
    #2
    Open up the Exit_Menu.skin, look for this line
    B01,55,418,366,60,"KillWinamp||QUIT","QUIT"
    and change to
    B01,55,418,366,60,"QUIT","QUIT"
    This has already been removed for the next version.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Smart Music - 04OCT09
    By ThunderStick in forum RR Released Plugins
    Last Post: 10-04-2009, 11:15 PM
  2. Ideal music player in a front-end - does anything like it exist?
    By mrpeenut24 in forum Software & Software Development
    Last Post: 03-04-2009, 06:54 AM
  3. Replies: 34
    Last Post: 11-06-2007, 03:42 PM
  4. Music Age/Organization
    By Quattro in forum Software & Software Development
    Last Post: 01-24-2006, 07:12 AM
  5. Replies: 2
    Last Post: 06-25-2005, 12:56 PM
