so, like the title says, almost everytime i open rr, it will default to teh first song of ehat ever playlist i am using.
I know i need to use the RRresume plugin, but i cant seem to figute out how to get it to work.
i have downloaded and registered(at least i think i did) RRextended, but debug.txt says that it is not able to allow the plugin to be enabled.
Code:
7/16/2009 9:47:40 PM: PLAYER: Winamp Version: 5.13
7/16/2009 9:47:40 PM: DirectDraw Count: 1 - []
7/16/2009 9:47:40 PM: No Phidgets interface detected.
7/16/2009 9:47:40 PM: Plugin Manager: loading Global Plugins...
7/16/2009 9:47:40 PM: Plugin Manager: Plugin Found: RRExtended
7/16/2009 9:47:40 PM: Plugin Manager: Warning Plugin RRExtended does not support Enabled Method
7/16/2009 9:47:40 PM: Plugin Manager: Plugin loaded (Global): RRExtended
7/16/2009 9:47:40 PM: Plugin Manager: Plugin Found: SkinTool
7/16/2009 9:47:40 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
7/16/2009 9:47:40 PM: Plugin Manager: Plugin loaded (Global): SkinTool
7/16/2009 9:47:40 PM: Plugin Manager: loading Global Plugins Completed.
7/16/2009 9:47:40 PM: LoadSkin: C:\Program Files\Road Runner\Skins\DigitalFX 4.0\
7/16/2009 9:47:40 PM: Plugin Manager: loading SkinDir Plugins...
7/16/2009 9:47:40 PM: Plugin Manager: loading SkinDir Plugins Completed.
7/16/2009 9:47:41 PM: Plugin Manager: Error loading (menu.skin): MOTIONLOCK (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
7/16/2009 9:47:41 PM: Plugin Manager: Warning Plugin MOVIETIMES does not support Enabled Method
7/16/2009 9:47:41 PM: Plugin Manager: Warning Plugin MOVIETIMES does not support Initialize Method
7/16/2009 9:47:41 PM: Plugin Manager: Plugin loaded (menu.skin): MOVIETIMES
7/16/2009 9:47:41 PM: Plugin Manager: Warning loading SKINTOOL (Attempt load more then once, most likely duped in globals and/or in skin).
7/16/2009 9:47:42 PM: Plugin Manager: Warning Plugin RRMEDIADB does not support Enabled Method
7/16/2009 9:47:42 PM: Plugin Manager: Warning Plugin RRMEDIADB does not support Initialize Method
7/16/2009 9:47:42 PM: Plugin Manager: Plugin loaded (menu.skin): RRMEDIADB
7/16/2009 9:47:43 PM: CheckResume: ResumeMusic=1 WasRadio=0
7/16/2009 9:47:43 PM: Enter Exec: False, menu.skin, , False
7/16/2009 9:47:43 PM: Que Exec: True, menu.skin,
what am i doing wrong?
