Results 1 to 5 of 5
Thread: Volume control and ASIO sound card in RR
    Jul 2006
    Brisbane, Australia
    Hi guys
    I bought a new USB sound card see: http://www.cakewalk.com/products/UAUM/UA1G.asp
    I thought I had it all working well until I tried using my GPS and the volume went to 100% and nearly blasted me out of the cab. On closer investigation, I realised that he problem is the ASIO drivers do not have a master volume control. I see Foobar and Winamp have an ASIO plugin which I will have a play with tomorrow but are there any pointers on which volume control RR should be configured to control?
    There is also a switch on the unit which disables the ASIO drivers and leaves everything with the standard Windows drivers So I might play with that as well... Too late at night here...Maybe that might restore the master voume control in the mixer...
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
    MySQL Error
    Oct 2004
    no need for asio drivers in a carpc...
    go with std wdm drivers
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jul 2006
    Brisbane, Australia
    Thanks Mitch but still no Master Volume Control, so it's not such a good one for a Car PC. Shows up as USB speakers
    RodW
    Jan 2008
    as quino(the rr mastermind )so kindly pointed out to me before, rr uses the master volume controler in the taskbar to control the volume, and if it isn't there, it wont control the device(the problem i had).
    asio was originally devloped for the music industry as a way to modify the audio signal in real time, and transmit it to a live audience.
    for most of us, we are using asio drivers as a way to modify the audio signal while it is still in the digital domain, to preserve teh signal. becasue we are not dealing w/ live sound, latency is not as important.
    the vst hosts that use asio require a asio driver for both the input and output, but at least some(console) allow for only one asio device (for both input and output). this makes any asio sound card driver useless(only output).
    almost everyone here that is interested in processing the audio uses virtual audio cable, or asio4all, and a vst host. some use only asio4all, and a vsthost, others use all 3.
    if this is all greek to you, you are going to have alot of research ahead of you.
    if you understand it all, you are welcome to tell me where to go
    Jan 2006
    asio4all will do, set the gps volume with wave in rr, then map the master volume control. winamp volume wont work.
  1. Volume control for ASIO / VST setups?
    By JuniorGeezer in forum High End Solutions
    Last Post: 07-19-2009, 12:35 PM
  2. Sound Processing and X-Meridian
    By qpwoeiruty999 in forum High End Solutions
    Last Post: 01-13-2009, 08:15 AM
  3. Replies: 8
    Last Post: 09-25-2007, 07:20 PM
  4. M-Audio with ASIO volume control
    By mkysimes2 in forum Road Runner
    Last Post: 04-17-2007, 12:25 AM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
