View Poll Results: What Radio do you use with RideRunner?
Voters
265. You may not vote on this poll
  • Directed / Visteon HD Radio
    107 40.38%
  • SiLabs/ADS
    65 24.53%
  • HQCT
    17 6.42%
  • WinTV (Added 10-25-09)
    2 0.75%
  • Cingery
    7 2.64%
  • RadioShark
    9 3.40%
  • Blaupunkt
    2 0.75%
  • D-Link USB
    8 3.02%
  • DAB using the Venice5 Chip
    8 3.02%
  • None
    40 15.09%
Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 91 to 100 of 153
Thread: What Radio do you use with RideRunner?
  1. #91
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Hello mitchjs.
    Tonight I tryed RR with the new radio control. You have done a good job.
    Now the RDS function of Silabs works well, I can display all the RDS information: PTY, TP etc.. Without the new version only RDSTEXT and RDSNAME worked.
    I have a suggestion to resolve the audio problem of Silabs.
    You know that it works only in the front channel. But if I capture audio with Line_In plugin of Winamp, I can manage audio on all the channel and also I can use AVS and equalizer on it. The only problem is that RR also streams the audio in the meanwhile and I cannot disable it. So I have a kind of echoes due to the double streaming (RR + WA). Can you add an option to disable the audio via RR for the Silabs? For example if I select the flag "use Line in" in the setup, RR can disable the internal audio management for the radio.
  2. #92
    MySQL Error
    Oct 2004
    johnny, exactly what i was thinking to disable the audio capture
    yes! i can do it
    also there is another option, there are opther usbradio.dlls one that uses filter graphs...
    if u switch to that, it might capture to all other channels, it might not, it might just be a issue with your sound card... and the disable audio is best option
    PLEASE PM we, lets work together on this
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #93
    Mar 2009
    Italy
    Today I modified my skin with the new command and all seems to be ok with Silabs.
    The only command that doesn't work is "mono". The audio remain stereo and the stereo indicator remain on.
    About the audio i PM you.
  4. #94
    MySQL Error
    Oct 2004
    there is no such command as "mono" on the silabs (at least known to the dll)
    and i cant see any reason to use it, if the station is so weak u cant get stereo... listen to another station
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #95
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by mitchjs View Post
    We need to know what radios are being used:
    going to use Cinergy Piranha since it's the best stick i could find that offers both DAB and DVB-T.. just need a good tuner for FM
  6. #96
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    hi mitchjs!
    i have all the 3 version of usbradio.dll source code, using direct sound - using stream sound - using fmod sound (stereo or quad version, i make new volume commands for each speaker and main radio volume)
    in my silabs external plugin + usbradio.dll i have all the function you need it (radioart using PI, TA News function, AF function ecc.)
    plus all the RDS EON features
    i will start the new version of plugin+dll next week, but if you want i can give an help hand for your project
    (if you don't know it, this is my plugin/dll)
    http://www.mp3car.com/vbulletin/rr-p...ight=carputer1
    i made it
    i use the mute or vol- to decrease the radio sound if the gps "speak" or the phone is ringing
    in italy we use sygic drive software as gps, my friend made a dll that send a message to my plugin on the gps "speak"
    for the phone the project of another friends is incomplete
    this is an old video example (the music is ugly but the sound of the silabs decrease on gps "speak")
    [media]http://www.youtube.com/watch?v=jSAjX33gceI[/media]
    (the gps simulation track is setup in hi speed)
  7. #97
    Dec 2006
    italy, sardinia
    Quote Originally Posted by JohnnySierra View Post
    Hello mitchjs.
    the streaming echo is the gap between rr stream and winamp stream, ~1,5 sec.
    it's the stream buffer of winamp that make this
    if you are using only winamp stream and change the frequence you will hear the frequence change after ~1.5 second (the lenght of winamp stream buffer)
    the streming will be better to be placed inside rr not inside winamp or player that use a long stream buffer
    (sorry for my english)
  8. #98
    MySQL Error
    Oct 2004
    spidemunz, at this point everything is working good... i havent implented any EON, since its not even used here, and is way beyond the scope of radio control
    the current radio module, does artwork, does ta, tp indicators, i might add a ONTAEvent
    but im not 100% sure how that all works, since TA isnt used here too...
    i have never heard a traffic announcement, not that i listen to RDS FM anymore... we hd radio now
    i have made a NO audio version of the usbradio.dll too, if someone wants to use the winamp line in plugin... if someone wants to use the direct show version, they can too
    radio mute is supported, if one wants to use it for gps speak...
    it might be best if there is anything to add, we add it to the radio module
    review what is currently done, look at the new radio commands.txt
    and i bet they could fit ur skin in a few mins
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #99
    Mar 2009
    Italy
    Spidermunz, I suggest some solutions (referring to no-audio dll):
    Quote Originally Posted by spidermunz View Post
    it's the stream buffer of winamp...
    With Jasper linein plugin the buffer size could be reduced.
    Reduce the Winamp Volume and the mp3 or radio volume is always lowest than gps volume. Is not necessary to completely mute the player.
  10. #100
    Dec 2006
    italy, sardinia
    ok try this usbradio using jasper, is back compatible with old rr usbradio
    it hasn't sound, it use only stereo stream, it has eon feature (the extension feature reguarding plugin+dll depends by my vb6 extension plugin)
    (is smaller then original usbradio because is compiled using the last versione of visual studio )
    Attached Files Attached Files
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 04:34 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  3. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 08:10 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
