View Poll Results: What Radio do you use with RideRunner?
Voters
265. You may not vote on this poll
  • Directed / Visteon HD Radio
    107 40.38%
  • SiLabs/ADS
    65 24.53%
  • HQCT
    17 6.42%
  • WinTV (Added 10-25-09)
    2 0.75%
  • Cingery
    7 2.64%
  • RadioShark
    9 3.40%
  • Blaupunkt
    2 0.75%
  • D-Link USB
    8 3.02%
  • DAB using the Venice5 Chip
    8 3.02%
  • None
    40 15.09%
Page 11 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 101 to 110 of 153
Thread: What Radio do you use with RideRunner?
  1. #101
    Apr 2007
    Infill G4 Test
    Mitch, this is the follow up on my 2nd test to provide more details.
    This is what I did on my Infill G4:
    1. Unzipped G4test.zip to C:\G4test\ which contains InfillG4Cmd.dll & SampleAPP.exe
    2. Ran SampleAPP.exe
    3. Clicked IsOpenINFILL, result "FALSE" (assume this is to check if it's loaded)
    4. Clicked Open INFILL, result "I/O Open Error!"
    5. Clicked Close INFILL, result "Close INFILL" (assume this does nothing cos it's not loaded in first place)
    Only the above 3 buttons Open INFILL, Close INFILL & IsOpenINFILL respond to clicks (see attached). The rest of the buttons does nothing (assume cos it's not loaded).
  2. #102
    MySQL Error
    Oct 2004
    carz, no need to post this stuff here, i will send the the rest of the dlls i got
    maybe its a dependent
    i dont know, if no go, then not much i can do...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #103
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    may want to check if any of the tray icons/background apps has a hold of the hardware...
    Ride Runner RR's Myspace
  4. #104
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    Quote Originally Posted by mitchjs View Post
    yes... i know, i dont fully understand all the AF, TP, TA stuff...
    so inital realease will be light
    is this Cinergy 600, a TV Card (with fm tuner)?
    i find this post in the "RR 08-01-2009 Release - Available NOW (Updated: 8/21)" discussion
    i don't want to belittle your work, on the contrary, but the radioart and presets are just a framework than a complete radio RDS plugin
    you wite me "review what is currently done, look at the new radio commands.txt
    and i bet they could fit ur skin in a few mins"
    nothing surprised me, each command did what I had already,
    The comparison between the two dll is precisely in the management of radio
    can not make a dll radio without knowing the meaning of the commands that are being
    with a reading of this guide you will really understand what think is to do in order to make a advanced plugin
    as I have said in private (i do not know if you read the message), it lacks one of the most important
    alternatives frequencies management
    the radio must handle them automatically without my having to lift a finger
    does not create the distraction that would be doing it by hand and watching the monitor
    many car accidents captain for even minor distractions
    As I told you you have a look at work done for my dll, you will notice the missing parts to your dll
    mine is not a negative criticism, indeed, is a fact that you could serve to make full use of radio,
    RDS of cinergy can be make it using the same code of the silabs, and in this way for all rds radio
    The document below will give you the knowledge needed
    I wanted to give you my help for that reason, ever that I have done a long time is the same thing you're doing now
    i have made all rds function of this documents, eccepts the tmc management, were i'm i can't receive the tmc signals and in italy the signals is crypted
    (if is necessary i olso have an rdbs guide)
    Attached Files Attached Files
  5. #105
    MySQL Error
    Oct 2004
    yes, i combined a lot of rds functions, that where done by robbie, into silabs, which prob have been done on your plugin.
    no stations use AF in USA (and many other places) this functionality can me exteded
    if one really wants it, and want their radio to automaticly retune...
    feel free to extend that functionality, if you need any thing added to usbradio.dll
    which isnt my dll... i got it from the googlecode pages
    we could use your dll, if it it uses directshow or wav capture, but fixes the names of the audio devices... ie "FM Radio" should be strstr not strcmp
    since in vista/win7 audio device names are prepened with type of audio device
    example "Radio Receiver [4 - FM Radio]"
    i can give u the source code to the silabs radio module
    and u can add commands/lables/indicators to add that AF functionality u need
    or you could code snipit me what u need
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #106
    MySQL Error
    Oct 2004
    i wont really notice anything the the usbradio.dll, for i dont have source to yours (i think)
    only the mess i could get from google code pages, it was very very hard to figure out exactly what to use
    i went with the one Guino worked on
    and everything with silabs is working good... at least reported by testers
    and the silabs testing i did myself
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #107
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    WOW just got my HD here in the UK, testing on desktop, with my finger as a arial , its fantastic, ok i can only get anolgue , but what a difference, just got to make a few mods to the HD unit like make a ground,from the rca and boom , bobs your uncle
    I highly recommend this unit even thou it dose not oick up digital freq's here
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  8. #108
    Dec 2006
    italy, sardinia
    ok i can add mine to your code, in this way all the skin can use the same command, and we have a complete rds system for all silabs users
    i have 3 usbradio.dll, one is in stream audio (if you don't use a stream reader such winamp we haven't audio)
    the second is directshow
    the therd use fmod library but have an audio bug (this version can be set in quadriphonic mode)
    users can be use the 1 or 2 dll, the one that prefeer
    we can write in pm to decide all things
  9. #109
    Sep 2009
    WinTV Radio
    Trying to set this up and having a fair amount of success thanks to your hard work. I have not been able to get my WinTV radio functional inside RR yet however. When I use the config gui, it won't save the WinTV setting and when I alter the rr.ini file directly, when I launch I get no sound and no ability to control the radio (app doesn't launch). If I launch the radio app prior to running RR, it can control it and closes it when I exit RR. If I don't, I have to kill the Ride Runner process to exit. I do get a beep when I'm running radio and launch the RR screen for it. If I don't lauch the radio app, here is the debug info: (I wonder about the Blaupunkt reference, but I cannot find where it is getting that directive)
    9/19/2009 9:02:15 PM: Start -- Version: 8/1/2009
    9/19/2009 9:02:15 PM: OS Type: Windows XP
    9/19/2009 9:02:15 PM: FileManager: FileMode = Legacy
    9/19/2009 9:02:15 PM: FileManager: mypath = C:\Program Files\RideRunner\
    9/19/2009 9:02:15 PM: FileManager: ProfilePath = C:\Documents and Settings\User\My Documents\RideRunner\
    9/19/2009 9:02:15 PM: Blaupunkt---> RadioStart
    9/19/2009 9:02:20 PM: Blaupunkt---> Blaupunkt.exe failure
    9/19/2009 9:02:20 PM: Master Vol: Master Volume/4
    9/19/2009 9:02:20 PM: GetLineControl Failed: 401
    9/19/2009 9:02:20 PM: No Treble Support
    9/19/2009 9:02:20 PM: No Bass Support
    9/19/2009 9:02:20 PM: No Master ON/OFF
    9/19/2009 9:02:20 PM: Source: Wave=&H1008/1
    9/19/2009 9:02:20 PM: Source: SW Synth=&H1004/2
    9/19/2009 9:02:20 PM: Source: Front=&H100A/3
    9/19/2009 9:02:20 PM: No Mute for Source
    9/19/2009 9:02:20 PM: Source: Rear=&H100A/4
    9/19/2009 9:02:20 PM: Source: Subwoofer=&H100A/5
    9/19/2009 9:02:20 PM: Source: Center=&H100A/6
    9/19/2009 9:02:20 PM: Source: SPDIF=&H1001/7
    9/19/2009 9:02:20 PM: Can't Open Source
    9/19/2009 9:02:20 PM: Source: Rear Blue In=&H100A/8
    9/19/2009 9:02:20 PM: Source: Mic Volume=&H1003/9
    9/19/2009 9:02:20 PM: Source: Rear Pink In=&H100A/10
    9/19/2009 9:02:20 PM: Source: CD Volume=&H1005/11
    9/19/2009 9:02:20 PM: Source: PC Speaker=&H1008/12
    9/19/2009 9:02:20 PM: PLAYER: Winamp Version: 5.56
    9/19/2009 9:02:20 PM: DirectDraw Count: 1 - []
    9/19/2009 9:02:20 PM: No Phidgets interface detected.
    9/19/2009 9:02:20 PM: Plugin Manager: loading Global Plugins...
    9/19/2009 9:02:20 PM: Plugin Manager: Plugin Found: SkinTool
    9/19/2009 9:02:20 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    9/19/2009 9:02:20 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    9/19/2009 9:02:20 PM: Plugin Manager: Plugin Found: Weather
    9/19/2009 9:02:20 PM: Plugin Manager: Plugin loaded (Global): Weather
    9/19/2009 9:02:20 PM: Plugin Manager: loading Global Plugins Completed.
    9/19/2009 9:02:20 PM: LoadSkin: C:\Program Files\RideRunner\Skins\eLite Lite\
    9/19/2009 9:02:20 PM: Plugin Manager: loading SkinDir Plugins...
    9/19/2009 9:02:20 PM: Plugin Manager: loading SkinDir Plugins Completed.
    9/19/2009 9:02:20 PM: CheckResume: ResumeMusic=0 WasRadio=0
    9/19/2009 9:02:21 PM: Enter Exec: False, menu.skin, , False
    9/19/2009 9:02:21 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    9/19/2009 9:02:21 PM: Executing:
    9/19/2009 9:02:21 PM: Leave Exec: False, menu.skin, , False
    9/19/2009 9:02:21 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
    9/19/2009 9:02:21 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
    9/19/2009 9:02:22 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||RADIO", False
    9/19/2009 9:02:22 PM: Que Exec: True, menu.skin, "ONBTNPRESS||RADIO", False
    9/19/2009 9:02:22 PM: Que Exec: True, menu.skin, "RADIO", False
    9/19/2009 9:02:22 PM: Executing: RADIO
    9/19/2009 9:02:23 PM: Que Exec: True, radio_player.skin, "ONSCREENCHANGE", False
    9/19/2009 9:02:23 PM: Leave Exec: False, radio_player.skin, ONSCREENCHANGE, False
    9/19/2009 9:02:24 PM: Enter Exec: False, radio_player.skin, , False
    9/19/2009 9:02:24 PM: Que Exec: True, radio_player.skin, "ONSONGSTART", False
    9/19/2009 9:02:24 PM: Leave Exec: False, radio_player.skin, ONSONGSTART, False
  10. #110
    Apr 2006
    Sydney, Australia
    I've got the HQCT -e version and haven't been able to use it at all due to having only Audio Out and MIC In on the motherboard I'm using.
    When I originally bought the HQCT I thought the sound would be streamed via the USB.
    I havent looked at it any further at this stage, and as I use my MIC In for mobile phone via BT, I didnt find a solution and gave up testing, also the MIC In option would only give mono.
    Should I move to a Silabs as I noticed Mitch mentioned the HQCT wasnt up there with the rest of the tuners? Seems it was a bad investement, DOH!
    I dont think we have HD radio available yet in Australia, so maybe I should throw out the HQCT-e and buy a USB digital TV tuner with radio?
    New Car PC Build list in progress
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 04:34 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  3. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 08:10 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
