View Poll Results: What Radio do you use with RideRunner?
Voters
264. You may not vote on this poll
  • Directed / Visteon HD Radio
    106 40.15%
  • SiLabs/ADS
    65 24.62%
  • HQCT
    17 6.44%
  • WinTV (Added 10-25-09)
    2 0.76%
  • Cingery
    7 2.65%
  • RadioShark
    9 3.41%
  • Blaupunkt
    2 0.76%
  • D-Link USB
    8 3.03%
  • DAB using the Venice5 Chip
    8 3.03%
  • None
    40 15.15%
Page 16 of 16 FirstFirst ... 678910111213141516
Results 151 to 153 of 153
Thread: What Radio do you use with RideRunner?
  1. #151
    Jul 2007
    Quote Originally Posted by thinkfta View Post
    You might want to check both fuses.
    One is inline with the 'accessory on' Wire (RED)
    There is also one in the little black box with the 12V and ground (Yellow and Black); you can snap it open and check the fuse- also 2A.
    I bought the Directed and it had both of them blown - thought i threw my $$ away until i checked.
    Good Luck
    Thinkfta
    Progress: -- -- >30%
    Ford F-250 SD: VIA 1.5GHz, 1G, 32G Patriot SSD, XPSP3, RR(04-2010), DX4, iGuidance 2009,
    Directed HD w/ mjs Cable
    Thanks, but both these fuses are exterior from the unit, no? I tried with the home PSU and it didn't work either
  2. #152
    Newbie thinkfta's Avatar
    Jul 2009
    Time to buy another radio ?
    I don't know of any internal fuses - i have not opened the case yet.
    You can try
    www.cartoys.com
    http://www.lightav.com/car/directeda...dmhd_1000.html
    www.ebay.com
    www.rush2112.net (there some other suggestions here)
    I was able to get one on ebay for about $50 US, including shipping.
    Thinkfta
    Directed DMHD1000 HDRadio w/ mjs Cable
  3. #153
    Dec 2007
    Sydney Australia
    Maybe now we should add "DAB/DAB+ with Venice 7 chip" as a polling option
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 03:34 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  3. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 07:10 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
