View Poll Results: What Radio do you use with RideRunner?
Voters
265. You may not vote on this poll
  • Directed / Visteon HD Radio
    107 40.38%
  • SiLabs/ADS
    65 24.53%
  • HQCT
    17 6.42%
  • WinTV (Added 10-25-09)
    2 0.75%
  • Cingery
    7 2.64%
  • RadioShark
    9 3.40%
  • Blaupunkt
    2 0.75%
  • D-Link USB
    8 3.02%
  • DAB using the Venice5 Chip
    8 3.02%
  • None
    40 15.09%
Page 2 of 16 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 153
Thread: What Radio do you use with RideRunner?
  1. #11
    Nov 2004
    St Louis
    Quote Originally Posted by mitchjs View Post
    i need someone who is using (ugh) the silabs
    what usbradio.dll does one use?
    and how the hell are you managing audio?
    my commentary:
    this tuner blows what a difference the Directed/visteon is!!!
    (even for plain FM)
    I haven't used the RR USBRadio.dll in an long time. I have the spidermuns v.8 on two systems and the FreeIce one on another. Audio is over USB on all cause I don't have an audio in. Mine works better than any other USB Radio tuner I've tried (especially after splicing into the car antenna). I know th HD radio is better, but it would have to feed into my system through the mic input and thats not stereo, thereby, defeating the purpose.
    The audio line is installed with the driver. It is named FM Radio and can be selected from within RR.ini/RRConfig. The line is muted by RR till use, but with spidermun's dll, the device is active as soon as RR is started so alerts can work without the radio being selected. The FreeIce dll is much faster and cleaner than Spidermuns, but only supports RDS, i.e., no TA,TS, AF\AF messages, MAF, News, or tuner setup.
  2. #12
    Constant Bitrate toyotatyrant's Avatar
    Aug 2007
    Hampton Roads VA
    Visteon all the way! It just works too well!
    ATTENTION FELLOW CAR PC ENTHUSIASTS, POWER ACOUSTIC = CAR PC KRYPTONITE!!!! AVOID AT ALL COSTS!!!!
    To my adoring fans, No my Toyota's gas pedal didn't get stuck! Instead I saw you crossing the street and decided to floor it! Unfortunately, I MISSED!!!
  3. #13
    MySQL Error
    Oct 2004
    GizmoQ, that is prob out of my scope for now...
    i will try to get basics working with silabs, which i think i got
    on the GOOD NEWS side
    I got HDRADIO COMPLETLY out of RRCORE!!!!!
    i will need a tester...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    Jun 2008
    Visteon HD as a normal FM, since there's no HD broadcast over here.Works great.
  5. #15
    MySQL Error
    Oct 2004
    FYI
    Cingery , is the most complicated code... all the RDS mess
    the person who did alot of it "robby" im not sure who he is
    is he around?
    who is the one person who actually is using this tuner?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #16
    Nov 2004
    St Louis
    That's what I get for opening my big mouth.
  7. #17
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    FYI
    is he around?
    Robby is probably busy elsewhere these days... but I'm the one who uses cinergy :P unfortunately, I'm in Brazil and the card is in the US...
    Ride Runner RR's Myspace
  8. #18
    MySQL Error
    Oct 2004
    OK, IM ready to TEST!!!!
    Silabs and HD Radio
    i could use 2 testers for each
    i tested it here, and it passes
    its best if i let others try...
    THE ONLY THING NOT CODED, its AUTO SCAN PRESETS SAVE, where it scans, and creates presets automaticly
    that will take much more work
    so i didnt want it to hold me up, on something i bet alot dont use
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    ANyone having problems using Visteon or directed tuners. I am on my 3rd tuner now and this one just died.
    Is this a common problem. I starting to suspect the cable. Using one of mitches cables that I bought more than a year ago.
    New Age Garmin - Skin for RR
  10. #20
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by ThunderStick View Post
    I am running one in 2 different cars with no troublr
    les. I even bought a spare early on when I got a great deal just in case. Are you sure they are dead. I can test in my truck if you like or I cn send you mine to test in yours if that helps.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 03:34 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  3. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 07:10 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
