View Poll Results: What Radio do you use with RideRunner?
Voters
265. You may not vote on this poll
  • Directed / Visteon HD Radio
    107 40.38%
  • SiLabs/ADS
    65 24.53%
  • HQCT
    17 6.42%
  • WinTV (Added 10-25-09)
    2 0.75%
  • Cingery
    7 2.64%
  • RadioShark
    9 3.40%
  • Blaupunkt
    2 0.75%
  • D-Link USB
    8 3.02%
  • DAB using the Venice5 Chip
    8 3.02%
  • None
    40 15.09%
Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 153
Thread: What Radio do you use with RideRunner?
  1. #41
    MySQL Error
    Oct 2004
    ON THAT NOTE, i complete a document, with the commands
    on my ftp
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #42
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Quote Originally Posted by PontiacGA View Post
    My first one stopped pulling in stations after a month or two. My second one seems to be fine. I even found out why my radio reception sucked. Make sure the radio isnt close to the monitor.
    Any idea what the core problem was? My tuner is under the front passenger seat of my 4-door crew-cab pickup, the monitor is in the dash, and the computer is behind the rear passenger-side seat. PLENTY of space between all these components. I got great reception when the computer was not installed in the truck (using the Visteon control module to play the radio). But the reception went completely to crap when I installed the computer. I thought at first that it might be Mitch's cable or the serial-USB adapter, but the reception is no better if I unplug those and plug the Visteon controller back in. Something in the computer seems to be creating some kind of interference. I just haven't figured out how to isolate or shield it.
    Thanks...
    Mark
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
  3. #43
    MySQL Error
    Oct 2004
    mstaedt, remove the computer, and the reception will be fine
    or one of its components
    clearly, something you got in the car, is NOT designed to be in a car.. infact the FCC might not like it all at!
    i would disconnect... 1 thing at a time... some device is BLASTING out RFI
    and prob alot of it, prob a poorly designed power supply
    good luck, it can be a ***** to figure it out...
    i had a BLADE audio amp trashing my AM, i pulled it for a MTX amp, and all is well!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #44
    MySQL Error
    Oct 2004
    OK, im done coding for a little bit...
    ON my FTP is latest...
    I have completed, HDRadio, Silabs, HQCT, Blaupunkt
    the HQCT is very dissappointing... feel bad for those using it... hopefully some things will fall into place to make it better....
    the blaupunkt is untested, but its almost identical to the HQCT, limited control
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #45
    MySQL Error
    Oct 2004
    ANYONE got a DLINK or WINTV that they not using anymore, or still using, but can share, so i can test the code?
    I have Tested/Testing: HDRadio, Silabs, HQCT
    I have a RadioShark on its way to me...
    there is the Blaupunkt, the WinTV, the Dlink...
    these might not even be used anymore...
    if someone is actively using the wintv, or dlink, contact me
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #46
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by mitchjs View Post
    I've got both here somewhere, i wouldn't called them actively in use, i can test for you though just as soon as i dig them out.
    Aha, found the dlink, can't find the wintv though.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  7. #47
    Nov 2004
    St Louis
    I've got a WinTV laying around but loading its drivers is a pain in the ***.
    OBTW, can I get a label for signal strength on the SILABs: "RDSSIGNAL"?
  8. #48
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just what i asked for giz lol....
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #49
    Jan 2009
    I am using Terratec Cinergy Piranha USB DVB-T TV And DAB Radio Tuner from play.com and installed a Herschman DAB car aerial. Using the application that came with the Terratec gave excellent DAB quality but I have no idea how to integrate it into riderunner interface? So this project get the thumbs up
  10. #50
    Nov 2004
    St Louis
    I just realized that RRNEXT/RRPREV, NEXT/PREV are coded differently from the way radio previously worked. NEXT/PREV should always be tied to the onscreen playlist/dirlist/customlist/etc. NEXT should tell RR go to the next item on the list. There are other commands to increase and decrease the Freq/Finetune, but tying NEXT/PREV to them leaves no way to manipulate the list.
  1. Radio solution with RDS & TA (TMC possible)
    By ReflexNPG in forum Hardware Development
    Last Post: 08-04-2009, 04:34 PM
  2. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  3. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 08:10 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
